2 Replies Latest reply on Apr 30, 2007 12:39 PM by Cosmo111927
    NetStream problem for FLV HELP!!!
    Cosmo111927
      Hi everyone,
      I'm building a client server appliction using flash: the client app is a projector that connects to a server and loads some sfw files from that server. One of these files is used to play videos...
      When I test this file locally it works: I run it on my computer and it fetches the videos on the server.
      The problem occurs when I load it through the projector; the projector is run from my computer, it then loads the mentionned swf from the server which in turn loads the videos from the server. So the swf and the videos both come from the server...
      I did a little debugging and I think it has something to do with the netconnection not being setup properly:
      this.m_oConnection_nc.connect(null);
      seems to be at fault and I'm wondering if I should put the domain name as an argument...
      Basically the _videoStatus function never gets callled so i assume the NetStream object is not instaciated...
      This is the class used by the swf that plays the video:
