5 Replies Latest reply on Jul 29, 2014 10:04 AM by IE Film Studios
    Audition Instrumentals?
    IE Film Studios Level 1
      Hello,
      Today, I was playing around a bit with Audition CS6, trying to remove the vocals from Justin Timberlake's "Not a Bad Thing." I had issues with it though, as the remove vocals and vocal enhancer could not fully remove his voice, nor did the music sound right, I was wondering, does anyone know how to make an instrumental version of this song?
      Thanks for your help,
      Jack Reynolds
        • 1. Re: Audition Instrumentals?
          Bob Howes Adobe Community Professional & MVP
          I'm afraid there's no magic, totally reliable way to do this.
          All the vocal eliminators I know--including Audition's--work on the basis that lead vocals are usually panned centrally in a mix with instruments panned left and right.  At the simplest, a vocal remover inverts on of the stereo tracks, hopefully causing the vocal to cancel itself out with other instruments remaining more or less intact.  As you can see, this is fraught with risk--anything else in the centre channel will also be cancelled while parts of the voice that aren't central (stereo reverb for example) will remain.
          Audition's "Centre Channel Extractor" on the Stereo Imagery menu is as good as any at trying to do this and better than most.  All I can suggest is having a play with the settings (including the FFT size on the advanced menu) and get things as good as you can.  However, I fear that the only way to get a totally clean instrumental version of anything is to either record it yourself or get access to the original multi track recordings from the record company.
          • 2. Re: Audition Instrumentals?
            ryclark Adobe Community Professional
            Another way if you have Music Sequencer software is to see if there are any MIDI arrangements of the backing tracks available on line anywhere.
            • 3. Re: Audition Instrumentals?
              SuiteSpot Level 4
              Or you could look for a karaoke version - though I suspect that the name of that Timberlake song is a misnomer
              • 4. Re: Audition Instrumentals?
                I just did a quick Google and there are several karaoke versions available.  At least one of them didn't sound bad (if you like Timberlake).
                • 5. Re: Audition Instrumentals?
                  Well, thanks for your help all. I'll just play around with my settings. If I get desperate enough, I'll get in touch with the recording company. As for karaoke versions, I have seen many of them and already looked into them, but none of them sound exactly like Justin's original song, which is a must for me.
                  Thanks again,
                  Jack Reynolds
