4 Replies Latest reply on Jul 31, 2014 1:42 PM by HarveyLiu
    How can add a progress bar into script?
    HarveyLiu
      I got a script for gen pdf
      I want put a progress bar, and make it working
      but I don't know where I can put the progress bar
      and how
      var doc = app.documents;
      app.findTextPreferences = null;
      app.findTextPreferences.underline = true;
      for(var i=0;i<doc.length;i++)
              var found = doc[i].findText();
              var _pages = [];
              for(var j=0;j<found.length;j++)
                      var txfms = found[j].texts[0].parentTextFrames;
                      for(var k=0;k<txfms.length;k++)
                              _pages.push(txfms[k].parentPage.name);
              for(var j=0;j<_pages.length;j++)
                      if(_pages[j] === _pages[j-1])
                              _pages.splice(j,1);
              if(_pages.length != 0)
                      app.pdfExportPreferences.pageRange = _pages.toString();
                      doc[i].exportFile(ExportFormat.PDF_TYPE, new File(doc[i].fullName.toString().replace(/\.indd$/i,".pdf")), false);
              _pages = [];
      //=================================================================== Can I put progress bar in here?
                 var counter = new Window("palette");
                 counter.prompt = counter.add("statictext",[0,0,80,20]);
                 counter.show();
                 var cells = app.activeDocument.allCellStyles;
                 for(var i = cells.length-1; i > 0; i--){
                 counter.prompt.text = String(i);
                 cells[i].verticalJustification = VerticalJustification.bottomAlign;
                 counter.close();
      alert("Done.");
      thanks
      Harvey
        • 2. Re: How can add a progress bar into script?
          hasvi Level 1
          Hi harvey,
          you can add this code in "front or back" part of your script, try this
          main();
          function main(){
                var progress_win = new Window ("palette");
          var progress = progress_bar(progress_win, 2, 'Processing ... Completed');
              delay(1);
                progress.value = progress.value+1;
              delay(1);
              progress.parent.close();
          // delay function found here
          //found here http://www.wer-weiss-was.de/theme157/article1143593.html
            function delay(prmSec){
            prmSec *= 1000;
            var eDate = null;
            var eMsec = 0;
            var sDate = new Date();
            var sMsec = sDate.getTime();
            do {
            eDate = new Date();
            eMsec = eDate.getTime();
            } while ((eMsec-sMsec)<prmSec);
          * Taken from ScriptUI by Peter Kahrel
          * @param  {Palette} w    the palette the progress is shown on
          * @param  {[type]} stop [description]
          * @return {[type]}      [description]
          function progress_bar (w, stop, labeltext) {
          var txt = w.add('statictext',undefined,labeltext);
          var pbar = w.add ("progressbar", undefined, 1, stop);
          pbar.preferredSize = [300,20];
          w.show ();
          return pbar;
          by
          hasvi
          • 3. Re: How can add a progress bar into script?
            Chinnadk Level 4
            Hi Harvey,
            Try this,
                    var _pages = [];
                                    _pages.splice(j,1);
                    _pages = [];
                counter.show();
                var w = new Window('palette');
                w.pbar = w.add('progressbar', undefined, 0, cells.length);
                w.pbar.preferredSize.width = 300;
                w.show();
                w.pbar.value = 0;
                    w.pbar.value += 1;
                counter.close();
            alert("Done.");
            Regards,
            Chinna
            • 4. Re: How can add a progress bar into script?
              HarveyLiu Level 1
              Hi, Chinna
              thank you for your help
              but the progress bar not really work
              may be the progress bar need to put at beginning
              Harvey
