3 Replies Latest reply on Aug 20, 2006 10:11 AM by Rothrock
    Flv Sound
      How do i kill the sound on an FLV file with action script?
        • 1. Re: Flv Sound
          the volume property should do it:
          • 2. Re: Flv Sound
            Rothrock Level 5
            I've only used FLVs in Flash 7. If you are using the NetStream technique you will need to attachSound to attach the audio portion of your FLV to a clip. You can then use the regular sound object methods.
            So after the attachVideo:
            myVol=new Sound(vol);
            • 3. Re: Flv Sound
              Rothrock Level 5
              PS: I'm not sure if daniel@senap's technique will work or not, but I think it won't allow you to control the FLV sound separate from other sounds in your file. I do know that my approach is a bit more complex, but it allows independent control.
