1. Re: Why doesn't Avid DNxHD show up in Encoder 2014, but is already in other applications?
thnord Jul 29, 2014 2:53 PM (in response to daveAndrade)Are you talking about DNxHD MXF OP1a or QuickTime DNxHD? Also, could you check to see if the MXF OP1a format is available in both Premiere and AME?
2. Re: Why doesn't Avid DNxHD show up in Encoder 2014, but is already in other applications?
daveAndrade Jul 29, 2014 3:29 PM (in response to thnord)sorry, I was referring to the DNxHD with the quicktime .mov wrapper.
Admittedly, I did not check on the DNxHD MXF OP1a in Premiere, but it is in AME.
Then again, because of my first sentence here, I am unsure if that matters. I did have to download the codecs for the quicktime wrapper straight from Avid. It worked fine in AME CC, but AME CC 2014, even after I reinstalled the codecs again, still doesn't see them.
3. Re: Why doesn't Avid DNxHD show up in Encoder 2014, but is already in other applications?
thnord Jul 29, 2014 9:12 PM (in response to daveAndrade)Please try launching AME while holding down the Shift key. This should clear your plug-in cache. Let me know if that resolves the issue for you.
4. Re: Why doesn't Avid DNxHD show up in Encoder 2014, but is already in other applications?
daveAndrade Jul 30, 2014 12:13 AM (in response to thnord)That did. Works fine now. Thanks for the help!
