4 Replies Latest reply on May 26, 2015 8:30 AM by Mike-Hardy
    Undo support around extendscript command
    JHowe99
      This probably should be obvious, but how can "undo" be supported for a custom command(in Framemaker 10?  I found app.beginUndoGroup() for another product but frame gives an unknown method call for this.
      The following will delete with Ctrl-Q, but "undo" remains greyed out.  Thanks in advance.
      function demoDelete() {
          var doc = app.ActiveDoc;
          if (!doc) {
              alert("No active document");
              return;
          var range = doc.TextSelection;
          if (range.beg.offset == range.end.offset) {
              alert("Need to select some text");
              return;
          doc.DeleteText(range);
      function Command(cmd) {
          app.beginUndoGroup("demoCsr Command");
          switch (cmd) {
          case 1111: {
              demoDelete();
          app.endUndoGroup();
      var cmd = DefineCommand(1111, "demoCsrXrefInsert", "demoCsrXrefInsert", "^q");
