5 Replies Latest reply on Jan 4, 2018 6:03 PM by WobertC
    Can I edit someone else's LR Smart Previews remotely?
    kaylapotterbaum
      I'm living overseas right now and I have a potential client who wants to start farming out wedding photography editing to me. As I've watched tutorials on smart previews, it seems to me that it should be possible for me to open and edit their smart previews from my computer in Norway. Is this true? And if so, would I need their catalog as well as smart preview LR folder? What is the best and most efficient way to go about doing this? Thank you!
        • 1. Re: Can I edit someone else's LR Smart Previews remotely?
          john beardsworth Adobe Community Professional & MVP
          It's not really a matter of "Can I edit someone else's LR Smart Previews remotely?" but more like this: "if my client sends me a catalogue with smart previews, can I use them to make adjustments and return the work to him or her?"
          What she or he will need to do is select the images and do File > Export as Catalog. Checking Smart Previews, but not negatives (originals) will generate a folder containing any work they have done and the smart previews. This will be much smaller than sending you the originals (assuming they are shooting big raw files).
          You can then do your adjustments in the catalogue and send it back. They then use File > Import from Another Catalogue to bring your work into their catalogue. That would be it.
          It's worth trying (and you could try the above workflow yourself before unleashing it on the client). You may find that you can make good enough adjustments by having the smart previews, but it's also possible that in some cases you'll find them insufficient - eg if you have cropped a high ISO shot and want to be sure about the noise reduction.
          John
          • 2. Re: Can I edit someone else's LR Smart Previews remotely?
            kaylapotterbaum Level 1
            Thank you very much for your response. I did a test with your suggestion and it worked great. I am almost in disbelief that someone could virtually send me a whole wedding to be culled through and edited... from anywhere in the world for 2-3gb total. Wow.
            • 3. Re: Can I edit someone else's LR Smart Previews remotely?
              Juan Kis
              Thank you for the answer. Can I add another question on the same topic ?
              I know if you send a catalog with the smart Previews the editon also can send you back just the xmp. But I don' know how they do that.
              Thank you,
              Juan
              • 4. Re: Can I edit someone else's LR Smart Previews remotely?
                leannes15861376
                hope you can help me.. i seem to be getting no where with figuring out how to do this. how do you open their catalog and their smart previews in my lightroom and send it back to them so that it syncs with their origionals?
                • 5. Re: Can I edit someone else's LR Smart Previews remotely?
                  WobertC Adobe Community Professional
                  A 'Client' sends you (the 'editor') a Catalog and Smart Previews folder by {Menu>File>Export as Catalog}-
                  You-
                  1) Create a new folder in your computer (eg.  Documents/Editing)
                  2) Place the Client's Catalog and SP folder in the new folder.
                  3) Double-click (or Right-click) on the catalog .LRCAT file to "Open" the Catalog.
                  ---(Your version of Lightroom must be compatible with the Client's version! )
                  4) Do all your edits in the Develop module,
                  5) Send the Client's Catalog back to them.
                  The 'Client' then Imports the catalog ( Menu>File>Import from another catalog) into their main catalog to see your edits.
                  And as in the Correct answer by John Beardsworth you can easily test all this yourself-
                  1) {Export as Catalog} with SPs from your main Catalog,
                  2) Open the 'exported' catalog.
                  3) Edit the images.
                  4) Open your main catalog and {Import from another catalog} to bring in the edits.
