3 Replies Latest reply on Jul 30, 2014 9:18 AM by joel_pau
    I need to do THIS
    Alberto_x137
      Hi all!!
      I need your help again. It's simple, I need to do what you see in the picture (I don't know how to say that s**t in english, sorry). One button like that you have to mark to be able to press the submit button
      If you have an example i will be eternally grateful.
      Thank you so much
        • 1. Re: I need to do THIS
          joel_pau Level 5
          You can begin using this code.
          sym.$( '<form><input type="checkbox">I have read and agree with the above terms and conditions</form>' ).appendTo( sym.$("Rectangle") );
          sym.$( ":checkbox" ).change( function() { console.log(event.type); } );
          :checkbox Selector | jQuery API Documentation
          This code also runs:
          sym.$( "input[type='checkbox']" ).change( function() { console.log(event.type); } );
          • 2. Re: I need to do THIS
            Alberto_x137 Level 1
            Thank you so much!! That code was perfect... exactly what i was searching
            A small detail, when you click the checkbox to bring forward the submit button I use the following code: sym.$("symbolname").css("z-index", "100"); and it's OK, but I also need when someone press again on the checkbox, disable the submit button again. Can you help me?
            Thank you very much again.
            • 3. Re: Re: I need to do THIS
              joel_pau Level 5
              You can try this code:
                function(){ $(this).parent().css("color","red").html("Thank you for sign in!"); }
              The checkbox is removed.
