3 Replies Latest reply on Jul 31, 2014 6:21 AM by Anit_Kumar
    Run ColdFusion on IIS Express
      I was trying to run ColdFusion on IIS Express. I have used ColdFusion's Web Server Configuration Tool to configure website on IIS. I wanted to configure it for IIS Express.
        • 1. Re: Run ColdFusion on IIS Express
          Anit_Kumar Adobe Employee
          IIS Express works well with ASP.NET and PHP applications (IIS Express Overview : The Official Microsoft IIS Site). ColdFusion is not tested with IIS express so far. You may try to use it and can explore the web/Adobe Forums, in case you face any issue.
          Anit Kumar
          • 2. Re: Run ColdFusion on IIS Express
            kenbaj Level 1
            As I have mentioned, I have used ColdFusion's Web Server Configuration Tool to configure website on IIS. Could you please enumerate the steps that the tool takes to configure IIS for ColdFusion. I know it creates 2 virtual directories (namely CFIDE & Jakarta) and adds handlers to applicationHost.config. I followed the same on IIS Express manually, but couldn't get it working.
            Here is the error I am getting:
            HTTP Error 404.3 - Not Found
            The page you are requesting cannot be served because of the extension configuration. If the page is a script, add a handler. If the file should be downloaded, add a MIME map.
            Most likely causes:
            • It is possible that a handler mapping is missing. By default, the static file handler processes all content.
            • The feature you are trying to use may not be installed.
            • The appropriate MIME map is not enabled for the Web site or application. (Warning: Do not create a MIME map for content that users should not download, such as .ASPX pages or .config files.)
            • If ASP.NET is not installed.
            Things you can try:
            • In system.webServer/handlers:
              • Ensure that the expected handler for the current page is mapped.
              • Pay extra attention to preconditions (for example, runtimeVersion, pipelineMode, bitness) and compare them to the settings for your application pool.
              • Pay extra attention to typographical errors in the expected handler line.
            • Please verify that the feature you are trying to use is installed.
            •            Verify that the MIME map is enabled or add the MIME map for the Web site using the command-line tool appcmd.exe.
              1. To set a MIME type, run the following command in the IIS Express install directory: appcmd set config /section:staticContent /+[fileExtension='string',mimeType='string']
              2. The variable fileExtension string is the file name extension and the variable mimeType string is the file type description.
              3. For example, to add a MIME map for a file which has the extension ".xyz": appcmd set config /section:staticContent /+[fileExtension='.xyz',mimeType='text/plain']
                         Warning: Ensure that this MIME mapping is needed for your Web server before adding it to the list. Configuration files such as .CONFIG or dynamic scripting pages such as .ASP or .ASPX, should not be downloaded directly and should always be processed through a handler. Other files such as database files or those used to store configuration, like .XML or .MDF, are sometimes used to store configuration information. Determine if clients can download these file types before enabling them.
            • Install ASP.NET.
            • Check the failed request tracing logs for additional information about this error. For more information, click here.
            Detailed Error Information:
            Module   StaticFileModule
            Notification   ExecuteRequestHandler
            Handler   StaticFile
            Error Code   0x80070032
            Requested URL   http://localhost:49248/index.cfm
            Physical Path   C:\Users\kbajpai\Documents\Code\DataRequest\datarequest\index.cfm
            Logon Method   Anonymous
            Logon User   Anonymous
            Request Tracing Directory   C:\Users\kbajpai\Documents\IISExpress\TraceLogFiles\DATAREQUEST
            More Information:
              This error occurs when the file extension of the requested URL is for a MIME type that is not configured on the server. You can add a MIME type for the file extension for files that are not dynamic scripting pages, database, or configuration files. Process those file types using a handler. You should not allows direct downloads of dynamic scripting pages, database or configuration files.
            View more information »
            • 3. Re: Run ColdFusion on IIS Express
              The steps to create connectors are IIS manual connector configuration | ColdFusion 10 . It has the details about the files/folders it touch base.
              Anit Kumar
