7 Replies Latest reply on Jul 30, 2014 4:47 AM by Dapeamel
    batch pdf export script problem
    Dapeamel Level 1
      Hello guys,
      I got problem with my code cause it doesn't work at all,
      Could someone help me to correct it
      it's something with the exportfile line13
      //==== Batch PDF =====\\
      /* InDesign JavaScript to Create PDFs of a batch of InDesign files using an export PDF preset */
      var myPDFExportPreset = app.pdfExportPresets.item("Smallest file size"); // Change myPDFpreset to the name of the preset you want to use
      var myFileLocation = Folder.selectDialog("Please select path to files");
      myFolder = new Folder ([myFileLocation]);
      myFolderContents = myFolder.getFiles("*.indd"); // array
      myFileAmount = (myFolderContents.length - 1);
      // ===== Open, Export as PDF, and Close files ===== \\
      for (i = myFileAmount; i >= 0; i--)
      app.open(File (myFolderContents[i]));
      app.activeDocument.exportFile(
        ExportFormat.pdfType,
        File(myFolder.fsName + "/" + app.activeDocument.name.split(".indd")[0] + ".pdf"),
        false,
        myPDFExportPreset
      app.activeDocument.close(SaveOptions.no);
        • 1. Re: batch pdf export script problem
          Sajeev Sridharan Level 4
          Try this, add your pdf preset name in your code like below...
              var myPDFExportPreset = app.pdfExportPresets.item("your preset name");//type your preset name here
            File(myFolder.fsName + "/" + app.activeDocument.name.split(".indd")[0] + ".pdf", myPDFExportPreset),
            false,
            myPDFExportPreset
          Vandy
          • 2. Re: batch pdf export script problem
            Jump_Over Level 5
            Hi Vandy,
            Why so quick?
            • preset is declared in the 1st line already.
            • We cannot include a preset into File() declaration.
            I suggest to add "new" before "File" in the beginning of line 14, since target file for export wasn't created already (it was but is not valid).
            I mean:
              13. ExportFormat.pdfType,
              14. new File(myFolder.fsName + "/" + app.activeDocument.name.split(".indd")[0] + ".pdf"),
            Jarek
            • 3. Re: batch pdf export script problem
              Oops.... you're right Jarek....
              Vandy
              • 4. Re: batch pdf export script problem
                Dapeamel Level 1
                hmm I didn't got it work actually
                could you send me a correct code snippet.
                Thank you in advance Jarek,
                • 5. Re: batch pdf export script problem
                  var myPDFExportPreset = app.pdfExportPresets.item("[Smallest File Size]"); // Change myPDFpreset to the name of the preset you want to use
                    false,
                    myPDFExportPreset
                  Vandy
                  • 6. Re: batch pdf export script problem
                    PDF preset name was mentioned wrongly in the code....
                    Vandy
                    • 7. Re: batch pdf export script problem
                      Dapeamel Level 1
                      works like a charm!
                      awesome cheers
