0 Replies Latest reply on Apr 20, 2007 6:10 PM by domanski
    Combobox and Modules
    domanski
      Hi all,
      I having the following problem:
      I am trying to create an application with three files: One is the main file (with a ModuleLoader component), the other two are simple forms with a combobox component each.
      The problem is that when I load one of the swf into de ModuleLoader and clicks over the combobox, the list drops down normally. But if I load the other file, the combobox does not work. Always (and only) the combobox of the first swf that I load works.
      To define which swf to load into the ModuleLoader, I am using HorizontalList.
      I already found a solution, a workaround (adding a MenuBar component into the main file - don't ask me why this works out), but I want a better solution.
      Can anyone help me?
