I am trying to use the f4fpackager on one of the centos amis (5.03) through amazon aws.
when I try to run the command I get the following:
-bash: f4fpackager: command not found
I have tried
export LD_LIBRARY_PATH=/opt/adobe/ams/tools/f4fpackager
but haven't had any success - has anyone got any ideas?
Craig
Can you try navigating to the f4fpackager installation directory with the following command?
cd /opt/adobe/ams/tools
And then try to launch f4fpackager as follows:
./f4fpackager
If need be, you can load libraries as follows:
export LD_LIBRARY_PATH=.
./f4fpackager
Hi, I was missing the ./ from the call (and needed to go a level further in with the cd statement)
