0 Replies Latest reply: Jul 31, 2014 2:21 PM by bodyart RSS
    how to edit source sequence from 'multicam mode' sequence (not bearing multicam icon)?
    bodyart
      I'm 'multicam editing' what i believe I setup as a regular sequence, then enabled (i believe by nesting) as opposed to a textbook multicam sequence setup with multicam icon where you setup a 'source' then a 'target' prior to starting.  my 'multicam' sequence that works like a charm does not bear the multicam icon.  Is there a difference between the two or are they essentially the same?
      I was able to switch cameras on the fly like a charm so i 'multicam' edited an entire show when I realized I had 1 minor audio-to-picture beat-mismatch to correct in the source.
      I read that to fix this, press Ctrl+Shift+F where you want to open the source sequence in the Timeline panel (and this did open expanded tracks as expected near that designated point in the timeline) so i made the quick edit and saved changes.  But now playing back my multicam sequence (that does not have a multicam icon), I'm not sure what i must do to see those changes so i can continue/finish my show edit?  it isn't automatically doing this as i would expect.
      i'm forced to wonder what's going on, what 'source' I actually edited, and how or if it is connected to my multicam sequence if at all.  my icons seem reversed to me i.e. the sequence with expanded independent a/v tracks bears the 'multicam' icon whereas the sequence I actually did the multicam switching on the fly does not bear the 'multicam icon' or the audio-picture realignment edit I made in the expanded tracks.
      if these two are related, why do edits in the expanded sequence not reflect in the collapsed.  is there any other way to reveal/expand the multicam sequence?  so confused.
      Message was edited by: Tanya Lee
