1 Reply Latest reply on Apr 25, 2007 4:27 AM by MergeThis
    Context IDs for MergedProjects
    OE3-chick
      Is there a straight-forward way to use Context IDs for merged WebHelp Pro projects - resulting in a single .h file that accounts for Context IDs in all of the sub-projects as well as the master project?
      I've read the article about cutting and pasting all the pieces-parts together ( http://www.grainge.org/pages/authoring/calling_webhelp/using_map_ids_merged.htm) - but I'm thinking there must be some other less manual/integrated method through the RoboHelp interface....?
      I'm using RoboHelp x5 for now.
      Thanks.
        • 1. Re: Context IDs for MergedProjects
          MergeThis Level 4
          Sorry, but any methods you'll find on Peter's or Rick Stone's sites are the straightforward solutions. While some might require an inordinate amount of manual gymnastics, they'll invariably be your only solution (unless you're provided several methods to accomplish your goals, as often occurs with Peter & Rick).
          Leon
