0 Replies Latest reply on Apr 24, 2007 11:38 AM by MaxVT103
    Problem With NetStream
    MaxVT103 Level 1
      I am trying to understand why the AS3.0 LiveDoc says that the NetStream.play() will accept either a string url or a URLRequest object to play the flv. When I try this it doesn't accept a URLRequest and when using a relative directory structure, "./" to obtain the current location, it cannot find the file even though when I use "./" on any other object that loads external assets it works fine. I think this is a bug but I am not sure if I am using it right. When I don't use either of those, the stream loads the flv fine so I'm pretty sure it is a bug. I haven't gotten Flash CS3 yet so I haven't been able to test it in that to see if the same problem occurs.
