6 Replies Latest reply on Aug 4, 2014 8:29 AM by kanaga kumar
    Create folder hierarchy
    Dapeamel Level 1
      Hello all!
      I need a function that creates folders,
      create folder A on target "C:/test/123/"
      if folder A exists on target "C:/test/123/" then create folder B on target "C:/test/123/"
      if folder B don't exists on target "C:/test/123/" then create folder B on target "C:/test/123/"
      if folder B exists then create folder C on target "C:/test/123/"
      Could someone help me with this function
      Thank you in advance
        • 1. Re: Create folder hierarchy
          Chinnadk Level 4
          Try this,
          var target = Folder.selectDialog("Choose a target folder");
          if(!(Folder(target+"/"+"Folder A")).exists)
                  new Folder(target + "/" + "Folder A").create();
          else if(!(Folder(target+"/"+"Folder B")).exists)
                  new Folder(target + "/" + "Folder B").create();
          else if(!(Folder(target+"/"+"Folder C")).exists)
                  new Folder(target + "/" + "Folder C").create();
          else
                  new Folder(target + "/" + "Folder D").create();
          Regards,
          Chinna
          • 2. Re: Create folder hierarchy
            Dapeamel Level 1
            Thank you very much Chinna,
            • 3. Re: Create folder hierarchy
              kanaga kumar Level 1
              Dear Chinna,
              I need create subfolders from folder A, please see the screen shot for more details:
              Thanks in advance
              kanaga kumar. k
              • 4. Re: Create folder hierarchy
                Johnwhite Level 1
                Hi Chinna
                Create a folder hierarchy is a very good idea, but
                can you add some function?
                I try to change it into this:
                but I don't know how to make it works?
                var
                  mySelected = Number( app.extractLabel("Choose a target folder") ),
                  myDialog = app.dialogs.add({name:"Create a folder hierarchy",canCancel:true});
                  with(myDialog){
                       with(dialogColumns.add()){
                           with(dialogRows.add()){
                                     staticTexts.add({staticLabel:"Please select a target folder for create a folder and sub folder hierarchy"});
                                 var
                                 mySelection = dropdowns.add({stringList:["01   Annual Report", "02   Interim Report", "03   Announcement", "04   Circular", "05   IPO"], selectedIndex: 0});
                if (myDialog.show() == true) {
                    var docs = app.documents;
                    main();
                    myDialog.destroy();
                if((Folder(target).exists)  // if folder exist aleart
                      alert("exist")
                    else {
                        cfh();
                function cfh(){
                    if (mySelection.selectedIndex == 0){ // Credate a new folder in the location of Annaul Report by type in the new name: (type in name by myself)
                var the_dialog = app.dialogs.add({name:"Credate folders"});
                with(the_dialog.dialogColumns.add()){
                        staticTexts.add({staticLabel:"Please Type in New floder's name:"});
                        var grep_string = textEditboxes.add({minWidth:200});
                the_dialog.show();
                        new Folder("~/Annual Report" + "/" + "//this place for type new folder's name by myself").create();
                    if (mySelection.selectedIndex == 1){ // Credate a new folder in the location of Interim Report by type in the new name: (type in name by myself)
                the_dialog.show();
                        new Folder("~/Interim Report" + "/" + "//this place for type new folder's name by myself").create();
                    if (mySelection.selectedIndex == 2){ // Credate a new folder in the location of Announcement by type in the new name: (type in name by myself)
                the_dialog.show();
                        new Folder("~/Announcement" + "/" + "//this place for type new folder's name by myself").create();
                    if (mySelection.selectedIndex == 3){ // Credate a new folder in the location of Circular by type in the new name: (type in name by myself)
                the_dialog.show();
                        new Folder("~/Circular" + "/" + "//this place for type new folder's name by myself").create();
                    if (mySelection.selectedIndex == 4){ // Credate a new folder in the location of IPO by type in the new name: (type in name by myself)
                the_dialog.show();
                        new Folder("~/IPO" + "/" + "//this place for type new folder's name by myself").create();
                var f = Folder("~/??/??/" );  //and then open what I create
                f.execute();
                Can you make it work?
                John
                • 5. Re: Re: Create folder hierarchy
                  Chinnadk Level 4
                  Hi Kanaga kumar,
                  Try this.
                          new Folder(target + "/" + "Folder A" + "/Test1").create();
                          new Folder(target + "/" + "Folder A" + "/Test2").create();
                          new Folder(target + "/" + "Folder A" + "/Test3").create();
                          new Folder(target + "/" + "Folder B" + "/Test1").create();
                          new Folder(target + "/" + "Folder B" + "/Test2").create();
                          new Folder(target + "/" + "Folder B" + "/Test3").create();
                          new Folder(target + "/" + "Folder C" + "/Test1").create();
                          new Folder(target + "/" + "Folder C" + "/Test2").create();
                          new Folder(target + "/" + "Folder C" + "/Test3").create();
                  else
                          new Folder(target + "/" + "Folder D" + "/Test1").create();
                          new Folder(target + "/" + "Folder D" + "/Test2").create();
                          new Folder(target + "/" + "Folder D" + "/Test3").create();
                  Regards,
                  Chinna
                  • 6. Re: Create folder hierarchy
                    Thanks for your coding chinna.
                    kanaga kumar. k
