6 Replies Latest reply on Aug 12, 2006 10:36 AM by Newsgroup_User
    Invalid session in FlexSessionListener.sessionDestroyed
    Duster_IDF Level 1
      I'm implementing a FlexSessionListener like:
      public void sessionDestroyed(FlexSession flexSession) {
      if (LOG.isInfoEnabled()) {
      LOG.info("Flex session destroyed: " + flexSession
      + flexSession.getUserPrincipal());
      unregisterSessions(flexSession); // accesses session attribute
      try {
      flexSession.removeSessionDestroyedListener(this);
      catch (LocalizedException e) {
      LOG.warn("Error during sessionDestroyed for " + flexSession, e);
      Using the flexSession parameter causes exceptions, which is surprising at best.
      Accessing a session attribute causes this:
      flex.messaging.LocalizedException: The FlexSession is invalid.
      at flex.messaging.FlexSession.checkValid(FlexSession.java:515)
      at flex.messaging.FlexSession.getAttribute(FlexSession.java:269)
      at com.acesis.security.SessionRegistry.unregisterSessions(SessionRegistry.java:492)
      at com.acesis.security.SessionRegistry.sessionDestroyed(SessionRegistry.java:345)
      at flex.messaging.FlexSession.destroy(FlexSession.java:250)
      at flex.messaging.endpoints.rtmp.RTMPFlexSession.close(RTMPFlexSession.java:42)
      at flex.messaging.endpoints.rtmp.NIORTMPConnection.invalidateFlexSession(NIORTMPConnection.j ava:221)
      at flex.messaging.endpoints.rtmp.RTMPFlexSession.invalidate(RTMPFlexSession.java:47)
      at flex.messaging.security.LoginManager.logout(LoginManager.java:192)
      at flex.messaging.services.AuthenticationService.serviceCommand(AuthenticationService.java:6 5)
      at flex.messaging.MessageBroker.routeCommandToService(MessageBroker.java:622)
      at flex.messaging.endpoints.AbstractEndpoint.serviceMessage(AbstractEndpoint.java:298)
      at flex.messaging.endpoints.rtmp.AbstractRTMPServer.dispatchMessage(AbstractRTMPServer.java: 682)
      at flex.messaging.endpoints.rtmp.NIORTMPConnection$RTMPReader.run(NIORTMPConnection.java:665 )
      at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPo olExecutor.java:643)
      at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolEx ecutor.java:668)
      at java.lang.Thread.run(Thread.java:595)
      Removing the FlexSessionListener causes this:
      at flex.messaging.FlexSession.removeSessionDestroyedListener(FlexSession.java:372)
      at com.acesis.security.SessionRegistry.sessionDestroyed(SessionRegistry.java:347)
      The FDS documentation doesn't specify that you cannot do anything with the flexSession in a sessionDestroyed call. The same code has worked, IIRC, in GMC 4. It seems that the behavior changed in GMC 5 or 6. I'm running the released bits now.
      Is this the intended behavior?
      Jürgen Failenschmid
        • 1. Re: Invalid session in FlexSessionListener.sessionDestroyed
          aBill Level 1
          In the SessionDestroyED event, it is not possible to get attribute. Thanks for bring out the doc issue. The way which I overcome this issue I have to have a map to store the information for the destroy into the sessionID
          String signoffUserName = (String) sessionPlayerMap.remove(flexSession.getId());
          William Chan
          • 2. Re: Invalid session in FlexSessionListener.sessionDestroyed
            Level 7
            That kind of defeats the purpose of being able to store attributes in the
            Flex session instance. Actually, I did that before FDS supported custom
            session attributes.
            Attributes aside, it is strange that the session lifecycle listener cannot
            be unregistered.
            J�rgen Failenschmid
            • 3. Re: Invalid session in FlexSessionListener.sessionDestroyed
              seth_hodgson Level 1
              Hi Jürgen,
              The behavior for session destruction notification matches the behavior defined by the Servlet spec and its HttpSessionListener interface. The behavior is to notify session destroy listeners after all attributes have been unbound from the session and the session have been invalidated. My opinion is that the destory listener hook as spec'ed isn't very useful (I'd have voted for pre/post hooks).
              If you want to do something on session shutdown, the safer approach is to create an instance of a class that implements the FlexSessionBindingListener interface on session creation and add it as an attribute on the new session. As long as no code removes this attribute from the session arbitrarily, when the session is destroyed this attribute will be unbound and its valueUnbound() callback will be invoked. You shouldn't base your logic in valueUnbound() on having access to attributes in the session, because other attributes may be unbound by the time your listener is unbound.
              Best,
              Seth
              • 4. Re: Invalid session in FlexSessionListener.sessionDestroyed
                Level 7
                I hear you. I am trying to use the attribute lifecycle notifications rather
                than the session lifecycle ones. It looks like it is a feasible workaround
                for what I need at this point.
                It still doesn't solve the exception when trying to unregister the session
                listener. That needs to be fixed in an updater.
                Also, I trust that Adobe will reconsider the usefulness of the session
                lifecycle notifications...
                J�rgen Failenschmid
                • 5. Re: Invalid session in FlexSessionListener.sessionDestroyed
                  Hi Jürgen,
                  I've logged a bug for the exception when you attempt to unregister a session destroy listener from an invalidated flex session.
                  I've also logged an enhancement request to implement a pre-destroy listener hook. The problem with that is that we're still stuck with the servlet spec, so while we could do this for RTMP based sessions, in the Http case we wrap the underlying app server's HttpSession and they don't give us a standard way to catch or fire a pre-destroy hook if it's possible at all.
                  Thanks for your feedback.
                  Best,
                  Seth
                  • 6. Re: Invalid session in FlexSessionListener.sessionDestroyed
                    Level 7
                    Thanks, Seth.
                    J�rgen Failenschmid
