I have a ColdFusion service that doing basic authentication using SQL and returning a structure as JSON
The structure has one element AUTHENTICATED = true . The JSON looks like below
"AUTHENTICATED": true
The service works just fine when using HTTP but when using HTTPS I get this error .
An error occurred while trying to encrypt or decrypt your input string: Input length must be multiple of 16 when decrypting with padded cipher.
Can anyone help me with this please?
Could you show us the code that is causing the error?
<cfcomponent accessors="true">
<cffunction name="loginUser" access="remote" returntype="struct" returnformat="JSON" >
<cfargument name="username" type="string" required="yes">
<cfargument name="password" type="string" required="yes">
<cfargument name="applicationId" type="string" required="yes">
<cfif GetAuthUser() neq "">
<cflogout>
</cfif>
<cfset var retargs = StructNew()>
<cfset retargs.authenticated="NO">
<cflogin>
<cfset euserArray = new doeadmin.services.everifyUserService().login(arguments.username, arguments.password) />
<cfset userCount = new doeadmin.services.everifyUserService().searchCount(arguments.username, arguments.password) />
<cfif userCount eq 1>
<cfset retargs.authenticated="YES">
<cfset session.uuid = #euserArray[1].getUserId()#>
<cfset session.firstName = #euserArray[1].getFirstName()#>
<cfloginuser name="#arguments.username#" password="#arguments.password#" roles="">
<cfelse>
</cfif>
</cflogin>
<cfreturn retargs>
</cffunction>
<cffunction name="logoutUser" access="remote" returntype="string" >
<cflogout/>
<cfreturn "YES"/>
</cffunction>
</cfcomponent>
Apparently nothing untoward about the code. So the error message is likely from Tomcat. As your Coldfusion code is correct, you are justified in reporting the issue as a bug.
Reported as a bug
+1 vote
