4 Replies Latest reply on Aug 1, 2014 4:51 PM by A.T. Romano
    Can premiere elements do the following?
    Highmeadowhiker
      1. rotate a clip?
      2. color correct a clip?
      3. modify brightness of a clip?
      4.  remove a portion of a clip in the middle of a clip?
        • 1. Re: Can premiere elements do the following?
          A.T. Romano Level 7
          Highmeadowhiker
          Yes to all.
          These are relatively easy tasks to perform. In the case of color correction and brightness adjust, often the outcome depends of the severity of the problem in the file's video.
          What version of Premiere Elements do you have and on what computer operating system is it running?
          Let start with those details. Then I will post how to information specific to what you are trying to do?
          Or, do you have any purchased  or tryout of Premiere Elements at the present time?
          We will be watching for your reply.
          ATR
          Add On...Sample of Color Correction and other effects information
          http://help.adobe.com/en_US/premiereelements/using/WS4B8135DA-083C-42eb-B09E-65070ECBC889. html#WSeffff8bffc802084cc1873012fdd6069b3-8000
          • 2. Re: Can premiere elements do the following?
            Highmeadowhiker Level 1
            I have installed perhaps 8 editions of Roxio Creator over the years, and have learned to use them.  As a home movie maker, I have used Roxio to make many dozens of DVDs and Blu-Ray.  My current version, NXT2 Pro, can do all those things and I sometimes need those features.  My problem with Roxio is frequent hang/freeze and appcrash.  I have likewise bought various versions of Adobe PSE.  With PSE 6 I bought a bundled PE 4.  Because I had already advanced pretty far on the Roxio learning curve, I never used PE 4.  My increasing unhappiness with the Roxio hangs and crashes brings me to considering buying the PE 12.
            It would help me make up my mind if you would give me specific page numbers or specific references to how I achieve those clip manipulations in PE 12.  I would rather do that than download a trial version of PE 12.
            BTW, Can PS 12 burn Blu-Ray?
            • 3. Re: Can premiere elements do the following?
              A.T. Romano Level 7
              Highmeasdowhiker
              Thank you for identifying the program of interest as Premiere Elements 12 on assumed Windows 7, 8, or 8.1 64 bit computer.
              We are not Adobe trying to sell you Premiere Elements (any version). This is user to user where this user tries to supply Premiere Elements users with customized answers to Premiere Elements questions.
              1. You can read the Premiere Elements 12 Help PDF that is available online, and it has Table of Content with clearly defined Chapters and subject matter under those Chapter titles including the items that I am about to mention
              http://helpx.adobe.com/pdf/premiere-elements_reference.pdf
              2. The Adobe Effects Reference link that I already gave you is an excellent one for sizing up the Effects situation, including Color Correction and Brightness.
              The header of that Effects Reference document has a list of categories to click on...Adjust for Brightness and Color Correction for Color Correction.
              In the Premiere Elements 12 Expert workspace you would find Color Correction under the fx Effects Tab/Color Correction. For
              Brightness, see fx Effects/Advanced Adjustments/Image Control. These particular effects you drag into the Timeline clip and then edit
              the effect under the Applied Effects Tab.
              3. In Premiere Elements 12, you can burn to DVD-VIDEO on DVD disc, AVCHD format on DVD disc, and Blu-ray disc format on Blu-ray disc.
              You can also burn to folder for DVD-VIDEO and AVCHD (VIDEO_TS Folder to take to DVD-VIDEO on DVD disc and the BDMV Folder to take to AVCHD on DVD disc with 3rd party software. No burn to folder for Blu-ray. And, Premiere Elements stop markers do not function at playback for AVCHD DVD or Blu-ray disc format on Blu-ray disc.
              4. As for Rotation...
              a. Right click the file on the Expert workspace Timeline, select Rotate 90 Right or Rotate 90 Left from the pop up menu.
              or
              b. Select the Timeline clip, go to Applied Effects Tab/Applied Effects Palette/Motion Panel expanded to find the Rotation option
              with more controls.
              Also check out Adobe TV Premiere Elements 12 for video tutorials.
              http://tv.adobe.com/show/learn-premiere-elements-12/
              You leave yourself open to a lot of surprises if you do not look at the Premiere Elements 12 tryout before purchase. It can crash like any other version of Premiere Elements or any other software given the appropriate circumstances (some explained, some not.)
              And I have no idea where you are coming from when you ask
              Is that supposed to represent Premiere Elements 12? The abbreviation made me wonder since PS typical is used to represent Photoshop and PSE is used to represent Photoshop Elements. I am assuming that you meant Premiere Elements and that PS was a typing mistake.
              Please review and consider.
              ATR
              • 4. Re: Can premiere elements do the following?
                A.T. Romano Level 7
                Highmeadowhiker
                A just in case note...your prior experience seems to be with Premiere Elements 4.
                Be advised that there is a marked change in the Premiere Elements 11 and 12 workspaces as compared to versions earlier than 11.
                ATR
