7 Replies Latest reply on Apr 26, 2007 8:14 AM by Rothrock
    xml help
    Damon Edwards Level 3
      I have images being pulled from a xml file and they spin around according to the cursor like a carousel, however, when i click one of the images, i have it set so all the others disappear and it brings up a Media Display...I'd like to put corresponding videos there from a xml file as well... how do i go about doing this so it pulls the right movie according to the image???
        • 1. Re: xml help
          bump
          • 2. Re: xml help
            Rothrock Level 5
            What have you learned in the last day on this issue?
            What do you mean how do you go about this? You do what you said. You need someway of hooking up the clip you clicked on with which video you want to show. So you can either put the FLV filenames into your original XML. Or if there are several different FLVs for each images perhaps you need to put the name of that XML in your first XML and then load that XML when you click on an image.
            I'm not quite following exactly how your project is set up.
            • 3. Re: xml help
              correct
              how do i put them in along with the image, so that each flv is attached to its corresponding image?
              <?xml version="1.0"?>
              <icons>
              <icon image="image/Dunne_Lexan.png"/>
              <icon image="image/Eley,-Howard_Lexan.png"/>
              <icon image="image/Gagne_Lexan.png" />
              <icon image="image/Hackney_Lexan.png" />
              <icon image="image/Hastings_Lexan.png"/>
              <icon image="image/Klee,-Randall_Lexan.png"/>
              <icon image="image/Rasmussen_Lexan.png"/>
              <icon image="image/Snyder,-Chris_Lexan.png"/>
              <icon image="image/Steckle,-Larry_Lexan.png"/>
              <icon image="image/Torres,-Jack_Lexan.png"/>
              <icon image="image/Crumley_Lexan.png" />
              <icon image="image/Chung_Lexan.png"/>
              <icon image="image/Buckles_Lexan.png"/>
              <icon image="image/Buchholz_lexan.png"/>
              <icon image="image/Brooks_Lexan.png"/>
              <icon image="image/Beall_Lexan.png"/>
              <icon image="image/Bailey_Lexan.png"/>
              <icon image="image/Anderson,-Bill_Lexan.png"/>
              <icon image="image/Alexander,-Lyn_Lexan.png"/>
              </icons>
              • 4. Re: xml help
                Rothrock Level 5
                An easy way would be:
                <icon image="image/Brooks_Lexan.png" video="video/Brooks_Lexan.flv"/>
                However that only attaches it to that node in your XML, at some point where you are loading in the images or such you will either need to get the video attribute and put it into a property in the clip, or have some way of looking up which node the image came from and matching up the video attribute.
                Are you making an array when you load in the XML or just keep it as an XML object?
                • 5. xml help
                  this is what ive got so far, as you can see, all images load 'Anderson.swf' im just not familiar with xml and getting the data from it.
                  thats what i have, but i have them pulling SWF files of the flv
                  This is what it looks like
                  import mx.utils.Delegate;
                  import mx.transitions.Tween;
                  import mx.transitions.easing.*;
                  var numOfItem:Number = new Number();
                  var radiusX:Number = new Number();
                  var radiusY:Number = new Number();
                  var centerX:Number = new Number();
                  var centerY:Number = new Number();
                  var speed:Number = new Number();
                  var perspective:Number = new Number();
                  var home:MovieClip = new MovieClip();
                  home = this;
                  radiusX = 400;
                  radiusY = 75;
                  centerX = Stage.width/2;
                  centerY = (Stage.height/3);
                  speed = 0.045;
                  perspective = 120;
                  theText._alpha = 0;
                  var xml:XML = new XML();
                  xml.ignoreWhite = true;
                  xml.onLoad = function() {
                  var nodes = this.firstChild.childNodes;
                  numOfItem = nodes.length;
                  for(var i=0; i<numOfItem; i++) {
                  var t = home.attachMovie("logo", "logo"+i, i+1);
                  t.angle = i * ((Math.PI*2)/numOfItem);
                  t.onEnterFrame = mover;
                  t.icon.inner.loadMovie(nodes .attributes.image);
                  t.ref.inner.loadMovie(nodes
                  .attributes.image);
                  t.icon.onRollOver = over;
                  t.icon.onRollOut = out;
                  t.icon.onRelease = released;
                  xml.load("icons.xml");
                  function released() {
                  trace(loadMovie("Anderson.swf", medDisp)
                  medDisp._x=400
                  medDisp._y=100
                  var t:MovieClip = home["logo"+i];
                  t.xPos = t._x;
                  t.yPos = t._y;
                  t.theScale = t._xscale;
                  delete t.icon.onRollOver;
                  delete t.icon.onRollOut;
                  delete t.icon.onRelease;
                  delete t.onEnterFrame;
                  if(t != this._parent) {
                  var tw:Tween = new Tween(t, "_xscale", Strong.easeOut,t._xscale, 0, 1, true);
                  var tw2:Tween = new Tween(t, "_yscale", Strong.easeOut,t._yscale, 0, 1, true);
                  var tw3:Tween = new Tween(t, "_alpha", Strong.easeOut,100, 0, 1, true);
                  } else {
                  var tw:Tween = new Tween(t, "_xscale", Strong.easeOut,t._xscale, 100, 1, true);
                  var tw2:Tween = new Tween(t, "_yscale", Strong.easeOut,t._yscale, 100, 1, true);
                  var tw3:Tween = new Tween(t, "_x", Strong.easeOut,t._x, 100, 1, true);
                  var tw4:Tween = new Tween(t, "_y", Strong.easeOut,t._y, 320, 1, true);
                  var s:Object = this;
                  tw.onMotionStopped = function() {
                  s.onRelease = unReleased;
                  function unReleased() {
                  delete this.onRelease;
                  trace(unloadMovie(medDisp));
                  var tw:Tween = new Tween(t, "_xscale", Strong.easeOut,0, t.theScale, 1, true);
                  var tw2:Tween = new Tween(t, "_yscale", Strong.easeOut,0, t.theScale, 1, true);
                  var tw3:Tween = new Tween(t, "_alpha", Strong.easeOut,0, 100, 1, true);
                  } else {
                  var tw:Tween = new Tween(t, "_xscale", Strong.easeOut,100, t.theScale, 1, true);
                  var tw2:Tween = new Tween(t, "_yscale", Strong.easeOut,100, t.theScale, 1, true);
                  var tw3:Tween = new Tween(t, "_x", Strong.easeOut,t._x, t.xPos, 1, true);
                  var tw4:Tween = new Tween(t, "_y", Strong.easeOut,t._y, t.yPos, 1, true);
                  t.icon.onRollOver = Delegate.create(t.icon,over);
                  t.icon.onRollOut = Delegate.create(t.icon,out);
                  t.icon.onRelease = Delegate.create(t.icon,released);
                  function mover() {
                  this._x = Math.cos(this.angle) * radiusX + centerX;
                  this._y = Math.sin(this.angle) * radiusY + centerY;
                  var s:Number = new Number();
                  s = (this._y-perspective)/(centerY+radiusY-perspective);
                  this._xscale = this._yscale = s*100;
                  this.angle += this._parent.speed;
                  this.swapDepths(Math.round(this._xscale)+100);
                  this.onMouseMove = function() {
                  speed = (this._xmouse-centerX)/14500;
                  • 6. Re: xml help
                    bump
                    • 7. Re: xml help
                      Rothrock Level 5
                      I'm sorry, there is a lot of code there and because you pasted it into the body of a message all the [ someletter ] (where someletter=i) messed up the formatting. If you are going to put code in a post, use the attach code button. That keeps all the formatting and all.
                      That being said, that is a lot of code to wade through. After a quick look as best I can, it seems that you are assigning an angle property to "t" you can also assign something like this:
                      t.movieToLoadOnClick=nodes.attributes.video
                      Then when you click on that icon you would just need to use the variable:
                      whateverTarget.loadMovie(this.movieToLoadOnClick);
                      I would suggest setting aside this project for a brief moment and just learning how to work with XML a bit. Start with a brand new Flash file and maybe just three nodes in a shorter xml file. Play with it a bit and get to know XML without the complications of all the other stuff. When you come back to this it will be a lot easier.
