1 Reply Latest reply on Apr 30, 2007 9:41 AM by tanzy_m
    DataGrid and TitleWindow problem - clicking header calls TitleWindow!
    tanzy_m
      Hi all,
      I'm really stumped by this, any help would be greatly appreciated!
      I have a DataGrid and a TitleWindow. I've been using a "click" command in the DataGrid i.e. click="launchViewer(event)".
      This is the code for the launchViewer :
      public function launchViewer(event:MouseEvent):void
      { /* Function launchViewer */
      var popUp:ViewWindow = ViewWindow(PopUpManager.createPopUp(this, ViewWindow, false));
      But now I find that if I click on the headers to sort the columns of the datagrid the TitleWindow gets called as well! Is there any way to recognise that if I click on a column header the TitleWindow function won't get called?
      I've tried using mouseOver but get this error:
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      Please help!
      Many thanks,
      Tanz
        • 1. Re: DataGrid and TitleWindow problem - clicking header calls TitleWindow!
          tanzy_m Level 1
          Here's a solution I found that worked for me:
          I used the call change="dgClicked(event)" instead of click="launchViewer(event)" in the Datagrid defintiion.
          The function dgClicked checks which row the cell clicked was in. If row 0 (the header) was the one clicked then do only normal sorting - ie don't call the TitleWindow popUp.
          public function dgClicked(event:ListEvent):void
          if ( event.rowIndex != 0){
          launchViewer(event);
          Also the definition of launchViewer had to change from a MouseEvent to a ListEvent:
          public function launchViewer(event:ListEvent):void
          Hope this helps someone else out!
          T.
