1 Reply Latest reply on Aug 2, 2014 3:10 AM by Teetan VK
    How can I combine two very good ideas together?
    Teetan VK Level 1
      I got two scripts
      both function: find-change on master
      I love both very mcuh
      but how can combine two scripts together?
      1st:
      if ( app.documents.length > 0 ) {
          if ( app.scriptPreferences.version >= 6 ) {
              app.doScript( main, ScriptLanguage.JAVASCRIPT , [], UndoModes.ENTIRE_SCRIPT, "Search in masterpages" );
          else {
              main();
      } else {
          alert ( "No documents open!" );
      function main() {
          // Your settings
          var searchList = [
              [ "USA" , "Obama" ],
              [ "rocket" , "sky" ],
              [ "New York" , "Los Angeles" ]
          app.findGrepPreferences = app.changeGrepPreferences = null;
          app.findChangeGrepOptions.includeMasterPages = true;
          var target = app.documents.everyItem().masterSpreads.everyItem().textFrames.everyItem();
          for ( var j = 0; j < searchList.length; j++ ) {
              var curSearch = searchList[j];
              app.findGrepPreferences.findWhat = curSearch[0];
              app.changeGrepPreferences.changeTo= curSearch[1];
              target.changeGrep();
      } // main
      made by Kai Rübsamen
      2nd:
      var myDocuments = app.documents.everyItem();
      var myLayers = myDocuments.layers.everyItem();
      //Locked text frames on master spreads are not touched.
      //If you want to unlock them you have to add something like this:
      //Unlock ALL page items in every document on spreads and master spreads (optional):
      myDocuments.pageItems.everyItem().locked = false;
      var myPageItemsOnNormalSpreads = myDocuments.spreads.everyItem().pageItems.everyItem();
      //Unlock the layers (optional)
      myLayers.locked = false;
      //Lock all first level page items on normal spreads
      //That leaves the page items on master spreads unlocked:
      myPageItemsOnNormalSpreads.locked = true;
      //Now for the GREP part:
      app.findGrepPreferences = changeGrepPreferences = null;
      app.findGrepPreferences.findWhat = "\\b20\\d+\\b";
      //Do the search on "all open document" level
      //That will return an array of arrays:
      var myTarget = myDocuments.findGrep();
      //Flattening the myTarget array:
      var flattenedFoundArray = [];
      for(var n=0;n<myTarget.length;n++){
          flattenedFoundArray = flattenedFoundArray.concat(myTarget[n]);
      //Change contents of found texts in flattened array:
      for(var n=flattenedFoundArray.length-1;n>=0;n--){
          flattenedFoundArray[n].contents = String(Number(flattenedFoundArray[n].contents) + 1);
      //Unlock all objects on normal spreads:
      myPageItemsOnNormalSpreads.locked = false;
      //Reset GREP find and change prefs:
      made by Uwe
      thanks
      Teetan
        • 1. Re: How can I combine two very good ideas together?
          Teetan VK Level 1
          Hi, everyone
          I try to combine to script together
          but got an error
          can you guys help me fix it?
              else {
                  main();
          } else {
          function main() {
              // Your settings
              var searchList = [
          } // main
          thanks
          Teetan
