1. Re: Jump to slide "On Exit" not working
ChloeBee Sep 12, 2014 9:04 AM (in response to mbreath)I have the same problem. The On Exit is disregarded entirely. I tried implementing a workaround using advanced actions and variables, but I need On Exit to be working for that too!
Totally stuck, so if anyone has a solution....
2. Re: Jump to slide "On Exit" not working
uniquescreennamelol Sep 12, 2014 9:11 AM (in response to mbreath)I think I've had a similar problem before but moved on to custom navigation where the user clicks a button/smart shape to return to the menu. Just assigned a button's "On Success" action to "Jump to slide..."
If you are simply looking for the project to Jump to Slide when the timeline is depleted, I'm not sure of how to deal with it.
3. Re: Jump to slide "On Exit" not working
mark20044 Sep 12, 2014 10:05 AM (in response to ChloeBee)You might try making another slide after the one you want the On Exit command to execute from, and assign an Advanced/Shared Action to execute On Enter on the new slide that jumps back to the menu.
