1 Reply Latest reply on Apr 20, 2007 4:07 PM by Monkey_House
    Error #1506 - definition
    illadelphiaWeaponX
      ReferenceError: Error #1056: Cannot create property reserved on _index_mx_managers_SystemManager.
      What does this error mean?
      It only pops up like every once in a while, when my application initially loads.
      My application is over 1800 lines of code, and I cannot figure out what the error even means to find it's location, or I would paste code!
      -Andrew
        • 1. Re: Error #1506 - definition
          Monkey_House
          I found this on another blog which may or may not help you.
          I got the same error.
          When I run my Flex2 application from Flex Builder and invoke a remoting method,
          the message 'ReferenceError: Error #1056: Cannot create property isError on
          mx.messaging.AcknowledgeMessage.' is displayed in the console window of
          Flex Builder. Though, the application works without problem.
          I checked the WebORB source code and Flex2 reference document.
          http://www.adobe.com/livedocs/flex/2/langref/mx/messaging/messages/ErrorMessage.html
          Then I found that 'isError' property is not defined in Flex2 AbstractMessage class
          and its subclasses, therefore such an error is occured at client side class mapping
          processing.
          $isError property defined in V3Message.php is used by V3Dispatcher.php(line 60)
          to determine if the message is error or not. So I changed the property name and
          access modifier, and added isError() method in V3Message.php as below:
          Code:
          abstract class V3Message
          // snip
          protected $error;
          public function isError() {
          return $this->error;
          public abstract function execute(Request $request);
          AckMessage.php(line 39) and ErrMessage.php(line 39) refers to the
          $isError property, so I changed it to $error.
          Lastly I changed the code in V3Dispacher.php(line 60).
          Code:
          if($v3Message->error()) -> if($v3Message->isError())
          The $error property of V3Message class and its subclasses is now
          protected, its value is not sent to Flash Player and the error is not occured.
