2 Replies Latest reply on Aug 3, 2014 8:36 PM by JJMack
    Mac or PC?
    choir mouse
      I'm buying a new computer or laptop for an extensive Photoshop project. Budget is under $2000. Mac or PC? What do you recommend? Thanks!
        • 1. Re: Mac or PC?
          deto_ws Level 4
          Hi Choir
          I prefer you to using Mac like a MacBook pro, cause PC cant displayed color be accurate you must calibrate before you using that
          regards
          Deto
          • 2. Re: Mac or PC?
            Have you used both OS  Mac and PC? Have you used either?  If you have a lot of experience running one or the other I would go with that OS.  Both platform use the same hardware. Both OS are preemptive multitask OS with multiprocessor support. Photoshop operation and performance is similar on both platforms.  There are minor differences because of OS support.differences. Some third party Plug-ins may be available for one or the other platform.  If you just starting to use Photoshop you have a lot to learn do not be to concerned about plug-ins. There may be more device support for PC then Mac but  if the machines is for Photoshop both platforms work and perform nearly the same. Laptop cost should be in the same price range also.
            Retina display: 15.4-inch (diagonal) LED-backlit display with IPS technology;
            2880-by-1800 resolution at 220 pixels per inch with support for millions of colors
            Specifications
            • 2.2GHz quad-core Intel Core i7
            • Turbo Boost up to 3.4GHz
            • 16GB 1600MHz memory
            • 256GB PCIe-based flash storage1
            • Intel Iris Pro Graphics
            • Built-in battery (8 hours)2
            • $1,999.00
            DELL
            XPS 15 Touch
            $1,949.99
            4th Generation Intel® Core™ i7-4712HQ Processor (6M, up to 3.3GHz)
            16GB DDR3L 1600MHz (8GBx2)
            1TB 5400 rpm SATA Hard Drive + 32GB mSATA Solid State Drive
            NVIDIA® GeForce® GT 750M 2GB GDDR5
            15.6 inch LED Backlit Touch Display with Truelife and QHD+ resolution (3200 x 1800)
            Intel® Dual Band Wireless-AC 7260 + Bluetooth 4.0
            61 WHr, 6-Cell Battery (integrated)
            Myself I went with a refurbished Dell Workstation used some old displays, tablet and printer I had.
            Dell Outlet Precision Fixed Workstation T5600, 825W Tower
            Genuine Windows 7 Professional 64-Bit Operating System DVD
            Processor: Intel Xeon Dual Six Core E5-2620 Processor (2.0GHz, 15M, 7.2 GT/s,Turbo)
            2GB NVIDIA Quadro 4000, Dual Monitor, 2DP & 1DVI (max resolution 2560x1600 two)
            8GB, DDR3 RDIMM Memory, 1600MHz, ECC (4 DIMMS)
            PERC H310 RAID Controller
            256 GB Solid State Drive
            500 GB SATA, 3.5 Inch, 10K Hard Drive
            8X DVD +/- RW Optical Drive
            English  Keyboard
            Dell USB Optical Mouse
            Precision T5600: 3 Year Basic Hardware Service with 3 Year
            $2,029.00 Dell Outlet
                 + $180 4TB external USB3 Disk
                    $316 32GB ECC memory
            Total $2,525,00
