1. Re: Is there a problem with Indesign effects exporting to PDF?
P Spier Aug 3, 2014 4:18 PM (in response to RAZ!)What happens when you try?
What settings do you use?
2. Re: Is there a problem with Indesign effects exporting to PDF?
RAZ! Aug 3, 2014 4:21 PM (in response to P Spier)Hi Peter, thanks for replying... Everything works as normal in Indesign but when I export to PDF the image which did have a drop shadow and bevel emboss effect is now flattened. I've done this a time & time again but have never had this problem?
3. Re: Is there a problem with Indesign effects exporting to PDF?
P Spier Aug 3, 2014 4:40 PM (in response to RAZ!)What settings are you using?
4. Re: Is there a problem with Indesign effects exporting to PDF?
RAZ! Aug 3, 2014 5:07 PM (in response to P Spier)Sorry but I'm trying to cover everything here because I have no idea what I'm looking for...
To create the PDF I'm using...
File / Adobe PDF Presets / Press Quality...
Standard = None, Compatibility = Acrobat 5 (PDF 1.4)
Then General = Optimise for Fast Web View, View PDF after exporting. Then Compression = Bicubic Downsampling to 300ppi for images above 450ppi, Automatic (JPEG) Tile size 128, Image Quality Maximum. The same settings for Greyscale Images. Monochrome Images = Bicubic Downsampling to 1200ppi for images above 1800ppi, Compression = CCITT Group 4, Compress Text & Line Art, Crop Image Data to Frames.
The usual marks, bleed and information.
Output = No Colour Conversion, Don't Include Profiles.
And the rest I don't touch.
Any ideas???
5. Re: Is there a problem with Indesign effects exporting to PDF?
P Spier Aug 3, 2014 5:19 PM (in response to RAZ!)Not yet.
A screen shot (zoomed in would be good) of an area with an effect in ID and the same area in the PDF might help.
6. Re: Is there a problem with Indesign effects exporting to PDF?
RAZ! Aug 3, 2014 5:29 PM (in response to P Spier) -
7. Re: Is there a problem with Indesign effects exporting to PDF?
P Spier Aug 3, 2014 5:42 PM (in response to RAZ!)I have no idea. Have you tried another preset, like PDF/x-4?
8. Re: Is there a problem with Indesign effects exporting to PDF?
RAZ! Aug 3, 2014 5:53 PM (in response to P Spier)I've been playing around in-between our conversation but with no luck as yet but I will give that a go... I've decided to take the graphic in question over to PSD to get the effect I'm after there. This job has taken too long already and I can't wait any longer!
I really want to thank you soooo much for all your help anyway and I'll let you know if I solve this riddle. It may be something I'm doing wrong but I'm pretty sure that the only variable that has changed is the new update for Indesign CC 2014 as it was definitely working before hand.
Take care and thanks again.
9. Re: Is there a problem with Indesign effects exporting to PDF?
Willi Adelberger Aug 3, 2014 9:28 PM (in response to RAZ!)Which program do you use to vie the PDF?
10. Re: Is there a problem with Indesign effects exporting to PDF?
RAZ! Aug 3, 2014 9:33 PM (in response to Willi Adelberger)Hi Willi, It opens up automatically in Adobe Acrobat XI Pro... Why what are your thoughts?
11. Re: Is there a problem with Indesign effects exporting to PDF?
Willi Adelberger Aug 4, 2014 1:21 AM (in response to RAZ!)Because only Adobe Acrobat or Reader can show PDFs correctly. If you would have used Apple Preview for example, any transparancy would not have been shown. But this is not the case here.
What is about your overprint preview? Does it look correct?
Or did you use spot colors?
12. Re: Is there a problem with Indesign effects exporting to PDF?
RAZ! Aug 5, 2014 4:19 PM (in response to Willi Adelberger)Hi Willi, Sorry for the late reply but I've been under some pressure to get this job out...
It looks OK in the Indesign overprint preview and I usually have my Acrobat set to view overprint as well so I turned it off & on just in case there was something happening there, but no luck!
I am using a spot colour in the background behind the graphic but not on the graphic itself, but I don't think that should effect it as I'm sure I've done this many times (But I am starting to doubt myself now... lol)?
13. Re: Is there a problem with Indesign effects exporting to PDF?
RAZ! Aug 5, 2014 4:27 PM (in response to RAZ!)Also just to let you know Peter.... I tried using PDF/x-4 with no luck!
14. Re: Is there a problem with Indesign effects exporting to PDF?
I am using a spot colour in the background behind the graphic but not on the graphic itself…
That is reason, why it looks like it looks. But what happens if you replace the spot to a process color?
15. Re: Is there a problem with Indesign effects exporting to PDF?
RAZ! Aug 5, 2014 4:42 PM (in response to Willi Adelberger)I tried replacing the spot with magenta but the same thing happens! I'm so confused...
16. Re: Is there a problem with Indesign effects exporting to PDF?
idsdi Sep 10, 2014 12:34 AM (in response to RAZ!)Just wondering if anyone has found a solution to this yet? I'm having exactly the same problem - bevel/emboss effects are not exporting to PDF using the new InDesign CC 2014, where they have worked in previous versions of Indesign. My gut feeling is this is a bug in the 2014 version, but I'd love to hear from Adobe on this? The pain being once you have worked on your file in 2014 it's a pain in the you know what to go back to a previous version! Which really ends up wasting valuable time as Raz has also found!
17. Re: Is there a problem with Indesign effects exporting to PDF?
rob day Sep 10, 2014 5:30 AM (in response to idsdi)Can you post an example file somewhere?
18. Re: Is there a problem with Indesign effects exporting to PDF?
idsdi Sep 10, 2014 8:19 PM (in response to rob day)Hi Rob,
I did a bit more testing since I last posted and I think I've narrowed my particular issue down to a combination of effects that causes the problem, and ultimately it looks like it is the "sheer angle" effect in combination with the bevel/emboss effect that sends things off into the weeds...
I've exported a PDF showing this problem - both shapes are a copy of each other, prior to a sheer angle of 5 degrees being applied to the top shape. You can download the test file from here...http://www.idsdi.com/dl/indesign/test_id_fault.pdf
An image of what it shows like in InDesign is here:
19. Re: Is there a problem with Indesign effects exporting to PDF?
rob day Sep 11, 2014 6:05 AM (in response to idsdi) -
20. Re: Is there a problem with Indesign effects exporting to PDF?
rob day Sep 11, 2014 6:15 AM (in response to idsdi)it's a pain in the you know what to go back to a previous version!
I also saved my test as IDML, opened it in CS6 and got the same problem, so it's not new with CC2014
21. Re: Is there a problem with Indesign effects exporting to PDF?
idsdi Sep 12, 2014 2:16 AM (in response to rob day)Yes after posting about the previous version I did that myself (ie the save as idml etc)...mmm, shall eat my words there :-) (my memory must have been back from CS3/CS4 days or earlier....oh well)
Thanks for the workaround to at least get something out - does this mean adobe are aware of the bug, or do we need to put a formal bug report in somewhere?
22. Re: Is there a problem with Indesign effects exporting to PDF?
rob day Sep 12, 2014 4:53 AM (in response to idsdi)does this mean adobe are aware of the bug
No idea.
