1 Reply Latest reply on Aug 4, 2014 11:02 PM by Sajeev Sridharan
    ExtendScript for Updating Links on InDesing 2014
    Tauba
      Hello everybody
      I am using this a script to update the image links inside my INDD files, but I am unable to use it on my inDesign 2014. Does anybody know what changed on the latest version that the method update(); is no longer updating the links?
      Here follows the code I have done to update the links
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
      var numberOfEntriesFound = 0;
      start();
      function start() {
          var targetFolder = Folder.selectDialog("Select a magazine folder to search for INDD files:");
          var targetFolderPath;
          if (targetFolder != null) {
              targetFolderPath = targetFolder.fsName;
          } else {
               exit();
          var topFolder = (new Folder(targetFolderPath));
          forEachDescendantFile(topFolder, doStuffIfdocument);
          if (numberOfEntriesFound == 0) {
               alert('Process finsihed: No INDD were found under the given folder.');
          } else {
               alert('Process finsihed: ' + numberOfEntriesFound + ' INDD files were updated.');
      function forEachDescendantFile(folder, callback) {
          var aChildren = folder.getFiles();
          for (var i = 0; i < aChildren.length; i++) {
              var child = aChildren[i];
              if (child instanceof File) {
                  callback(child);
              } else if (child instanceof Folder) {
                  this.forEachDescendantFile(child, callback);
              } else {
                  throw new Error("The object at \"" + child.fullName + "\" is a child of a folder and yet is not a file or folder.");
      function doStuffIfdocument(oFile) {
          if (matchExtension(oFile, "indd")) {
              numberOfEntriesFound++;
              var document = app.open(oFile);
              try {
                  doStuff(document);
              } finally {
                  document.close(SaveOptions.YES);
      function doStuff(document) {
          document.links.everyItem().update();
      /*********** HELPERS FUNCTIONS ********************/
      * Returns true if the name of the given file ends in the given extension. Case insensitive.
      * @param {File} iFile
      * @param {String} sExtension The extension to match, not including the dot. Case insensitive.
      * @return {boolean}
      function matchExtension(iFile, sExtension) {
          sExtension = "." + sExtension.toLowerCase();
          var displayName = iFile.displayName.toLowerCase();
          if (displayName.length < sExtension.length) {
              return false;
          return displayName.slice(-sExtension.length) === sExtension;
