Hi all,
I could not find a good JavaScript for support of multi-lingual BC sites so I have created my own script that will replace the URL pathname and do conditional redirects to support multi-language sites. Don't know if it's overkill but it works as expected and the code is easy to read. Don't know how efficient the code is, probably a javascript ninja can do it better.
It now has everything needed for multi-language support such as:
The script does seem to work on mobile devices, I have tested it on Android 4.3 and 2.3.6
Found an edge case. If you selected a language when on the root page you get redirected to /[_language]/ (eg /_se/) which does not work they will get a Page not found. Therefore you should have a list of suggested links on the Page not found page.
Subfolder without trailing / works, for example: /_se by making it as a page and then do a 301 redirect to /_se/index
Check it out here: https://gist.github.com/Molnfront/da1f0bd7a0264fa8f477
Example here: http://cashnew.businesscatalyst.com (switch between English and Swedish. Default english)
