2 Replies Latest reply on Aug 5, 2014 1:25 PM by creativejoan0425
    Dropdown list remember last selected
    creativejoan0425 Level 1
      I have a dropdownlist dialog, and I want to remember last selected, and next time when I run the script the selectedIndex will be the last selected index, for example, when I select number 3, it will type 3 in the insertionPoints, and next time I run the script again, I want the Selected:3
      myDisplayDialog();
      function myDisplayDialog(){
      var myDialog = app.dialogs.add({name:"Symbol_v1.0"});
        with(myDialog.dialogColumns.add()){
        with(dialogRows.add()){
        with(dialogColumns.add()){
        staticTexts.add({staticLabel:"Selected: "});
                      var mySymbolArray = ["1","2","3","4","5"];
                      var myEachSymbol = mySymbolArray.toString().split(",");
                         var myDropdownsTran = dropdowns.add({stringList:mySymbolArray, selectedIndex:0});
                          //myDropdownsTran = dropdowns.add({stringList:mySymbolArray, selectedIndex:0});
      var myResult = myDialog.show();
        if(myResult == true){
              app.selection[0].texts[0].contents  = myEachSymbol[myDropdownsTran.selectedIndex];
        • 1. Re: Dropdown list remember last selected
          Jump_Over Level 5
          What if nothing selected... or unintentionally some text is selected... or you will run a dialog after few days of break...
          Filling a contents of some doc's textFrame is a weak solution.
          You could use app.insertLabel("key_name","key_value") method.
          It will keep "key_value" till your app.preferences stay unreset. Check it:
          myDisplayDialog();
          var mSel = Number(app.extractLabel("Dialog_1_dropdown_sel"));    // to read a value
          if ( isNaN(mSel) ) mSel = 0;     //     to set 1st run with 0
            var myDropdownsTran = dropdowns.add({stringList:mySymbolArray, selectedIndex:mSel});
            app.insertLabel( "Dialog_1_dropdown_sel", String(myDropdownsTran.selectedIndex) );     // to write a value
          Warning. You need to remember "key_name" cause there is no way to list existing keys.
          Jarek
          • 2. Re: Dropdown list remember last selected
            Thx Jarek, it very helpful
