3 Replies Latest reply on Aug 9, 2014 1:13 PM by Dobygm
    How can I make a long list find-change only on Master
    Teetan VK Level 1
      Hi everyone
      I got this script:
      var myDocuments = app.documents.everyItem();
      var myLayers = myDocuments.layers.everyItem();
      //Locked text frames on master spreads are not touched.
      //If you want to unlock them you have to add something like this:
      //Unlock ALL page items in every document on spreads and master spreads (optional):
      myDocuments.pageItems.everyItem().locked = false;
      var myPageItemsOnNormalSpreads = myDocuments.spreads.everyItem().pageItems.everyItem();
      //Unlock the layers (optional)
      myLayers.locked = false;
      //Lock all first level page items on normal spreads
      //That leaves the page items on master spreads unlocked:
      myPageItemsOnNormalSpreads.locked = true;
      //Now for the GREP part:
      app.findChangeGrepOptions.includeMasterPages = true;
      app.findGrepPreferences = changeGrepPreferences = null;
      app.findGrepPreferences.findWhat = "\\b20\\d+\\b";
      //Do the search on "all open document" level
      //That will return an array of arrays:
      var myTarget = myDocuments.findGrep();
      //Flattening the myTarget array:
      var flattenedFoundArray = [];
      for(var n=0;n<myTarget.length;n++){
          flattenedFoundArray = flattenedFoundArray.concat(myTarget[n]);
      //Change contents of found texts in flattened array:
      for(var n=flattenedFoundArray.length-1;n>=0;n--){
          flattenedFoundArray[n].contents = String(Number(flattenedFoundArray[n].contents) + 1);
      //Unlock all objects on normal spreads:
      myPageItemsOnNormalSpreads.locked = false;
      //Reset GREP find and change prefs:
      made by Uwe
      I change it into this, aim to make a mulit items of find-change only on master
      app.findGrepPreferences.findWhat = "USA";
          flattenedFoundArray[n].contents = "CHINA";
      app.findGrepPreferences.findWhat = "Washington DC";
          flattenedFoundArray[n].contents = "Beijing";
      only what I can do is repeat and repeat again
      is that another perfect solution to do that?
      thanks
      Teetan
        • 1. Re: How can I make a long list find-change only on Master
          Sajeev Sridharan Level 4
          Try this,
          findChange("USA", "CHINA");
          findChange("Washington DC", "Beijing");
          function findChange (findWhat, changeContent){
              if(findWhat)app.findGrepPreferences.findWhat = findWhat;
                  if(changeContent)flattenedFoundArray[n].contents = changeContent;
          Vandy
          • 2. Re: How can I make a long list find-change only on Master
            Teetan VK Level 1
            Perfect!
            Thank you Vandy, thank you so much!
            Teetan
            • 3. Re: How can I make a long list find-change only on Master
              Dobygm
              this is perfect,
              I am new to coding. How could this be applied only to the active story. To simplify script code?
              Thank you very much.
