7 Replies Latest reply on Aug 5, 2014 2:12 AM by Dapeamel
    Problem with create a folder
    Dapeamel Level 1
      Hello guys,
      I wrote this code
      var myWindow = new Window ("dialog","Laredoute Strukturskapare");
      myWindow.orientation = "column";
      myWindow.add ("statictext", undefined, "write a number (example:342344)");
      var Jobnr = myWindow.add ("edittext", undefined, "");
      Jobnr.active = true;
      Jobnr.characters =40;
      myWindow.add ("button", undefined, "OK");
      myWindow.add ("button", undefined, "Avbryt");
      new Folder("/xxxx/xxx/xxx/" + Jobnr+ "/testcreatefolder").create(); ;
      myWindow.show ();
      the problem is, the script creates a folder on correct location but the folder name is "[object EditText]"
      Could someone help me to correct the code?
      Thank you in advance
        • 1. Re: Problem with create a folder
          Chinnadk Level 4
          Modified
          var ok = myWindow.add ("button", undefined, "OK");
          ok.onClick = function ()
                  new Folder("/xxxx/xxx/xxx/" + Jobnr.text+ "/testcreatefolder").create();
          myWindow.show ();
          • 2. Re: Problem with create a folder
            Dapeamel Level 1
            the code is almost working
            just problem
            when I press "OK" or "Avbryt" nothing happens why?
            if I press ok then it creates the folder.
            if I press Avryt =cancel + close prompt
            • 3. Re: Re: Problem with create a folder
              Chinnadk Level 4
              Try this.
                      myWindow.close();
              var Avbryt = myWindow.add ("button", undefined, "Avbryt");
              Avbryt.onClick = function ()
                      myWindow.close();
              myWindow.show ();
              Regards,
              Chinna
              • 4. Re: Problem with create a folder
                Sajeev Sridharan Level 4
                var canc = myWindow.add ("button", undefined, "Avbryt");
                canc.onClick = function ()
                        myWindow.close();
                myWindow.show ();
                Vandy
                • 5. Re: Problem with create a folder
                  Dapeamel Level 1
                  it works like a charm but when I press ok the prompt its still there,
                  is it possible to make the prompt is closing too? but it still creating  the folder
                  Thank you in advance.
                  • 6. Re: Problem with create a folder
                            myWindow.close();
                    • 7. Re: Problem with create a folder
                      Dapeamel Level 1
                      Thank you guys all are solved!!!
