Hi all,
I've got a Flex2 server instance on JRun4, ColdFusion 7.0.2
running as another application.
I can setup the config files using the
"coldfusion.flash.messaging.ColdFusionAdapter" service declarartion
in the services part of the services-config.xml file. As in below:
[services]
[service id="coldfusion-flashremoting-service"
class="flex.messaging.services.RemotingService"
messageTypes="flex.messaging.messages.RemotingMessage"]
[adapters]
[adapter-definition id="cf-object"
class="coldfusion.flash.messaging.ColdFusionAdapter"
default="true"/]
[/adapters]
[destination id="ColdFusion"]
[channels]
[channel ref="my-cfamf"/]
[/channels]
[properties]
[source]*[/source]
[!-- define the resolution rules and access level of the cfc
being invoked --]
[access]
[!-- Use the ColdFusion mappings to find CFCs, by default
only CFC files under your webroot can be found. --]
[use-mappings]false[/use-mappings]
[!-- allow "public and remote" or just "remote" methods to
be invoked --]
[method-access-level]remote[/method-access-level]
[/access]
[property-case]
[!-- cfc property names --]
[force-cfc-lowercase]false[/force-cfc-lowercase]
[!-- Query column names --]
[force-query-lowercase]false[/force-query-lowercase]
[!-- struct keys --]
[force-struct-lowercase]false[/force-struct-lowercase]
[/property-case]
[/properties]
[/destination]
[/service]
[service-include file-path="remoting-config.xml" /]
[service-include file-path="proxy-config.xml" /]
[service-include file-path="messaging-config.xml" /]
[service-include file-path="data-management-config.xml" /]
[/services]
This setup, however, renders the default rtmp channel
definition useless (I've tried changing ports, etc) - any time I
try to do a producer.send, I get the error
"Client.Error.MessageSend:Send failed:Channel.Connect.Failed error
undefined url:'rtmp://localhost:2038'".
As soon as I remove the coldfusion-specific remoting service,
the rtmp stuff works great - but now I can't connect to CFC's in my
CF app.
I get the exact same results when replacing the default
remoting-config.xml file w/ the stuff from the cf remoting service
declaration sample above.
Is it possible to run these two services in the same
application server?
To clarify, I want to communicate to CFC's in the ColdFusion
app, but I want the Flex apps to talk to one-another without using
the CF rtmp gateway.
Thanks - any help much appreciated!
