8 Replies Latest reply on Aug 20, 2014 4:31 PM by pen_test
    How to echo a Flash variable in Php
    pen_test
      Okays.Let me start off by saying,"i am a noob".With that said,just ignore my poor explanation.I ve' been struggling to figure out what it is that is missing in my incoherent AS2 codes. What i am trying to achieve is very simple yet,confusing as i am still very new to several statements in AS2. My code below is accepting input from user(s).Then sends entered input to a Php file...which in-turns prints the entry in a new window.(some kinda test i choose to do).
      AS 2 code --->
      stop();
            submit_btn.onRelease = function() {
          if (Age_txt.text != '') {
      var send_lv:LoadVars = new LoadVars();
      var receive_lv:LoadVars = new LoadVars();
         send_lv.numby =Age_txt.text;
        send_lv.sendAndLoad("goto.php", receive_lv, "POST");
           getURL("goto.php", "_blank", "POST");
          } else {
         error_box.text = 'Fill fields correctly';
      Php goes like -->  <goto.php>
      <?PHP
      $catch=$_POST['numby'];
      $hollaback='your fake age is $catch';
      if($_POST[numby]) {
      echo $hollaback ;
        }else {
               echo "you have entered nothing"; }
      PS: The getURL() in my line 8 is just my way of forcing 'goto.php' to tell me what it caught in it's memory. I do not wish to send the msg back to flash via error_box.
        THANKS ALOT PEOPLES!
        • 1. Re: How to echo a Flash variable in Php
          use:
          stop();
          receive_lv.onData=function(src:String){
          trace(src);  // or use a textfield to display those echos
          trace("sending "+Age_txt.text);  // for debugging
             //  getURL("goto.php", "_blank", "POST");
              } else {
          <?PHP
          if($_POST[numby]) {
          echo $hollaback ;
            }else {
          • 2. Re: How to echo a Flash variable in Php
            pen_test Level 1
            Not trying to be an asse but Php would never print a flash variable with just an ECHO statement especially when the variable would have to be returned to the flash dynamic textfield(error_box) name.
            Apart from this, while i am not very sure IF i need the trace(), your code above is correct.And seriously, i am not lazy to try.. it is just not working.I d' suggest(if you have time) for you to do a test run on the above code.. you might u/stand my frustration. However,thanks a bunch..after-all, you r not being paid to help me
            • 3. Re: How to echo a Flash variable in Php
              AGAIN:  trace(src);  // or use a textfield to display those echos
              • 4. Re: How to echo a Flash variable in Php
                pen_test Level 1
                So,i did all you told me(traced all stages..)the output panel proved good.But php did not receive anything. So i flipped the script from the above into this--->
                AS Code [i made changes to onData() by using .onLoad() in Line 4 ]
                stop();
                send_lv.onLoad = function(ok) {      //trying to make it available for php by onload
                  if (ok) {
                  error_box.text = 'Going for handshake with php,Thanks!!';     // decided to use textfield to display the echos
                  } else {
                  (error_box.text='Sorry..No Php');
                  trace("sending: "+Age_txt.text);
                  // for debugging
                  send_lv.Age = Age_txt.text;
                  trace("Age: "+send_lv.Age);     //  I traced like this: +send_lv.Age instead of this: +Age bcos this: +Age gives an error in the output panel
                  send_lv.sendAndLoad("goto.php", "receive_lv", "POST");
                  trace(receive_lv);
                  //getURL("goto.php", "_blank", "POST");
                  } else {
                then in Php, i swapped only between  _POST['Age'] for this: _POST['Age_txt] and backwards several times trying diff outcomes..yet NO JOY!
                • 5. Re: How to echo a Flash variable in Php
                  no.  you have more than one error.
                  just copy the code i suggested in message 1.  don't make any changes to my code.
                  you can add additional code (esp, if you need to use a textfield while testing and/or you want to add more trace functions).
                  • 6. Re: How to echo a Flash variable in Php
                    pen_test Level 1
                    Went on a break to get a straight head..Using this on php gave me an error.
                    $catch=$_POST['Age_txt'];
                    echo "&ASpipeline=$hollaback&";
                    I used your code above(with little or no changes made).. ran it on my server. Php would flag back an error.Meanwhile, i saw/found no error from the AS2 code.now i really dont know why the variable isn't echoed back to flash //i used a dynamic txt to display msg..
                      trace(src);
                      if (ok) {
                       error_box.text = receive_lv.ASpipeline;}
                       else{
                       error_box.text="error at server end";
                       }// or use a textfield to display those echos
                    trace("caught: "+Age_txt.text);  // for debugging
                        } else {
                    Now really short of ideas. Is it possible that the Flash player on my pc is the reason why these codes wont run?I use flash 8 professional.
                    • 7. Re: How to echo a Flash variable in Php
                      now your php code is incorrect.
                      again, use:
                      stop();
                          } else {
                      //  <goto.php>
                      <?PHP
                      if($_POST[numby]) {
                      echo $hollaback ;
                        }else {
                      • 8. Re: How to echo a Flash variable in Php
                        pen_test Level 1
                        Sir, I used as described in msg 7 but my swf output panel says "undefined".
                        Please and please again, what am i missing? Specifically, what is undefined in my AS2 code? Thanks and sorry for my slow assimilation.
