2 Replies Latest reply: Aug 6, 2014 6:46 PM by gwhPoster RSS
    Using a second blog for a testimonials page
    gwhPoster Community Member
      I'm building a site for someone who will be purchasing the webMarketing hosting plan so I won't have access to any webApps. To get around this problem, I've created a second blog to be used to manage testimonials. I've created a page and have inserted the following module tag:
              {module_blogpostlist,12775,3 template="/ModuleTemplates/Testimonials/testimonials-list-alt.tpl"}
      The above references the testimonials blog with an ID of 12775 and it points to a custom list layout. When I test though by loading the html page, it shows the default list layout used for blogs under Module Templates and not my custom one.
      I just wondered if anyone could tell me if it's actually possible to use an alternate list and detail layout for a second blog?
      Thanks in advance.
        • 1. Re: Using a second blog for a testimonials page
          madasafish77 Community Member
          I've implemented this and a little video gallery as well using the blogs. Just make sure you are referencing the correct template file and that it's extension is .tpl and not html. You can see a live example here. Testimonials
          Here is a copy of the code I used with pagination as well. You will need this to get the pagination working.
          jPages
                  <script>
            /* when document is ready */
            $(function() {
              /* initiate plugin */
              $("div.holder").jPages({
                containerID: "itemContainer",
             perPage: 4
            </script>
          HTML
          <div class="holder">
                  </div>
                  <ul id="itemContainer">
                      {module_blogpostlist,12460,100 template="/ModuleTemplates/WebApps/Testimonials/testimonials-test.tpl"}
                  </ul>
                  <hr />
          Hope this helps
          • 2. Re: Using a second blog for a testimonials page
            Thanks so much for that code. That's exactly what I need and the paging works great. Also the path to the .tpl file was spelt incorrectly which is why it wasn't reflecting correctly.
            Thanks again - I really appreciate it.
