0 Replies Latest reply on Aug 6, 2014 12:31 PM by MatthewTurley
    bug/issue: Lightoom 5 Publish Services / 'Rename To'
    MatthewTurley
      I believe I've found a bug (or at least a design oversight) within Lightroom 5 Publish Services (Hard Drive):
      I've created a Publish Connection that uses the 'Copy name' token in the file renaming scheme. However, I've found that if I change an image's copy name, and 'Mark to Republish', it won't use the updated copy name. It seems once an image is published within a Publish Connection, its export filename is forever locked. The only solution I've found is to delete & recreate the Publish Folder.
      system info
      Lightroom 5.6
      OS X 10.9.4
      MacPro
