0 Replies Latest reply on Apr 18, 2007 6:10 PM by ToBeNamedLater
    java CreateObject with static constructor
      I'm using the Smack API library From Javasoft in a ColdFusion app. So far so good.
      But now I want to change the presence indicator. The problem is that the Presence constructor takes a typesafe enum class as a parameter. I can't figure out how to get at it.
      The constructor from the Smack API:
      Constructor Summary
      Presence(Presence.Type type)
      Creates a new presence update.
      Nested Class Summary
      static class Presence.Type
      A typsafe enum class to represent the presence type.
      As documented
      The working code is pretty straightforward (Code block 1).
      but now I need to add the presence stuff.
      Code Block 2 fails generally
      Code Block 3 errors with "Object Instantiation Exception".
      How do I access a static nested class in order to call the constructor?
      Enum Presence.Type
