3 Replies Latest reply on Aug 6, 2014 3:23 PM by JJMack
    Can't select anchor points of some shapes in Photoshop CC 2014
    kd360
      I have a multi-layered file with a number of shape objects. When I go to the direct selection tool and try to click on an anchor point the points simply do not show up. Is there some property that I am not aware of that prevents selection?
        • 1. Re: Can't select anchor points of some shapes in Photoshop CC 2014
          Are you targeting the correct post a screen capture that shows you problem where Photoshop image window Layers Palette and Paths Palette are visible. Example
          • 3. Re: Can't select anchor points of some shapes in Photoshop CC 2014
            Can you upload the psd file.  The Path palette shows a very small triangle path on the right edge of the canvas up some from the bottom of the document. With the direct path tool active and the shape layer targeted even if no point is selected I would expect the see the path outline shown in the Path Palette for the shape layer to be shown in the image window also I see none. Can you see the path outline? Are you  on a Mac I'm on a PC using cc2014 with todays update
            here is my Photoshop System Info...
            Adobe Photoshop Version: 2014.1.0 20140730.r.148 2014/07/30:23:59:59  x64
            Operating System: Windows 7 64-bit
            Version: 6.1 Service Pack 1
            System architecture: Intel CPU Family:6, Model:13, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading
            Physical processor count: 12
            Logical processor count: 24
            Processor speed: 1995 MHz
            Built-in memory: 40886 MB
            Free memory: 34729 MB
            Memory available to Photoshop: 37129 MB
            Memory used by Photoshop: 94 %
            3D Multitone Printing: Disabled.
            Touch Gestures: Disabled.
            Windows 2x UI: Disabled.
            Image tile size: 1024K
            Image cache levels: 4
            Font Preview: Huge
            TextComposer: Latin
            Display: 1
            Display Bounds: top=0, left=0, bottom=1080, right=1920
            Display: 2
            Display Bounds: top=0, left=-1360, bottom=768, right=0
            OpenGL Drawing: Enabled.
            OpenGL Allow Old GPUs: Not Detected.
            OpenGL Drawing Mode: Advanced
            OpenGL Allow Normal Mode: True.
            OpenGL Allow Advanced Mode: True.
            AIFCoreInitialized=1
            AIFOGLInitialized=1
            OGLContextCreated=1
            NumGLGPUs=1
            NumCLGPUs=1
            glgpu[0].GLVersion="3.0"
            glgpu[0].GLMemoryMB=2048
            glgpu[0].GLName="Quadro 4000/PCIe/SSE2"
            glgpu[0].GLVendor="NVIDIA Corporation"
            glgpu[0].GLVendorID=4318
            glgpu[0].GLDriverVersion="9.18.13.4052"
            glgpu[0].GLRectTextureSize=16384
            glgpu[0].GLRenderer="Quadro 4000/PCIe/SSE2"
            glgpu[0].GLRendererID=1757
            glgpu[0].HasGLNPOTSupport=1
            glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
            glgpu[0].GLDriverDate="20140702000000.000000-000"
            glgpu[0].CanCompileProgramGLSL=1
            glgpu[0].GLFrameBufferOK=1
            glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.40 NVIDIA via Cg compiler"
            glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
            glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
            glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
            glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
            glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
            glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
            clgpu[0].CLPlatformVersion="1.1"
            clgpu[0].CLDeviceVersion="1.1 CUDA"
            clgpu[0].CLMemoryMB=2048
            clgpu[0].CLName="Quadro 4000"
            clgpu[0].CLVendor="NVIDIA Corporation"
            clgpu[0].CLVendorID=4318
            clgpu[0].CLDriverVersion="340.52"
            clgpu[0].CUDASupported=1
            clgpu[0].CUDAVersion="6.5.12"
            clgpu[0].CLBandwidth=7.49684e+010
            clgpu[0].CLCompute=185.005
            License Type: Subscription
            Serial number: 96040035116912554961
            Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2014\
            Temporary file path: C:\Users\JOHNJM~1\AppData\Local\Temp\
            Photoshop scratch has async I/O enabled
            Scratch volume(s):
              F:\, 465.2G, 173.4G free
              C:\, 224.2G, 102.3G free
            Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2014\Required\Plug-Ins\
            Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2014\Plug-ins\
            Installed components:
               A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
               ACE.dll   ACE 2014/04/14-23:42:44   79.554120   79.554120
               adbeape.dll   Adobe APE 2013/02/04-09:52:32   0.1160850   0.1160850
               AdbePM.dll   PatchMatch 2014/04/23-10:46:55   79.554276   79.554276
               AdobeLinguistic.dll   Adobe Linguisitc Library   8.0.0
               AdobeOwl.dll   Adobe Owl 2014/03/05-14:49:37   5.0.33   79.552883
               AdobePDFL.dll   PDFL 2014/03/04-00:39:42   79.510482   79.510482
               AdobePIP.dll   Adobe Product Improvement Program   7.2.1.3399
               AdobeXMP.dll   Adobe XMP Core 2014/01/13-19:44:00   79.155772   79.155772
               AdobeXMPFiles.dll   Adobe XMP Files 2014/01/13-19:44:00   79.155772   79.155772
               AdobeXMPScript.dll   Adobe XMP Script 2014/01/13-19:44:00   79.155772   79.155772
               adobe_caps.dll   Adobe CAPS   8,0,0,13
               AGM.dll   AGM 2014/04/14-23:42:44   79.554120   79.554120
               ahclient.dll    AdobeHelp Dynamic Link Library   1,8,0,31
               amtlib.dll   AMTLib (64 Bit)   8.0.0.91 BuildVersion: 8.0; BuildDate: Tue May 27 2014 22:3:7)   1.000000
               ARE.dll   ARE 2014/04/14-23:42:44   79.554120   79.554120
               AXE8SharedExpat.dll   AXE8SharedExpat 2013/12/20-21:40:29   79.551013   79.551013
               AXEDOMCore.dll   AXEDOMCore 2013/12/20-21:40:29   79.551013   79.551013
               Bib.dll   BIB 2014/04/14-23:42:44   79.554120   79.554120
               BIBUtils.dll   BIBUtils 2014/04/14-23:42:44   79.554120   79.554120
               boost_date_time.dll   photoshopdva   8.0.0
               boost_signals.dll   photoshopdva   8.0.0
               boost_system.dll   photoshopdva   8.0.0
               boost_threads.dll   photoshopdva   8.0.0
               cg.dll   NVIDIA Cg Runtime   3.0.00007
               cgGL.dll   NVIDIA Cg Runtime   3.0.00007
               CIT.dll   Adobe CIT   2.2.6.32411   2.2.6.32411
               CITThreading.dll   Adobe CITThreading   2.2.6.32411   2.2.6.32411
               CoolType.dll   CoolType 2014/04/14-23:42:44   79.554120   79.554120
               dvaaudiodevice.dll   photoshopdva   8.0.0
               dvacore.dll   photoshopdva   8.0.0
               dvamarshal.dll   photoshopdva   8.0.0
               dvamediatypes.dll   photoshopdva   8.0.0
               dvametadata.dll   photoshopdva   8.0.0
               dvametadataapi.dll   photoshopdva   8.0.0
               dvametadataui.dll   photoshopdva   8.0.0
               dvaplayer.dll   photoshopdva   8.0.0
               dvatransport.dll   photoshopdva   8.0.0
               dvaui.dll   photoshopdva   8.0.0
               dvaunittesting.dll   photoshopdva   8.0.0
               dynamiclink.dll   photoshopdva   8.0.0
               ExtendScript.dll   ExtendScript 2014/01/21-23:58:55   79.551519   79.551519
               icucnv40.dll   International Components for Unicode 2013/02/25-15:59:15    Build gtlib_4.0.19090
               icudt40.dll   International Components for Unicode 2013/02/25-15:59:15    Build gtlib_4.0.19090
               igestep30.dll   IGES Reader   9.3.0.113
               imslib.dll   IMSLib DLL   7.0.0.145
               JP2KLib.dll   JP2KLib 2014/03/12-08:53:44   79.252744   79.252744
               libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
               libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
               libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
               LogSession.dll   LogSession   7.2.1.3399
               mediacoreif.dll   photoshopdva   8.0.0
               MPS.dll   MPS 2014/03/25-23:41:34   79.553444   79.553444
               pdfsettings.dll   Adobe PDFSettings   1.04
               Photoshop.dll   Adobe Photoshop CC 2014   15.1
               Plugin.dll   Adobe Photoshop CC 2014   15.1
               PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   5.0.0
               PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   5.0.0.74
               PSArt.dll   Adobe Photoshop CC 2014   15.1
               PSViews.dll   Adobe Photoshop CC 2014   15.1
               SCCore.dll   ScCore 2014/01/21-23:58:55   79.551519   79.551519
               ScriptUIFlex.dll   ScriptUIFlex 2014/01/20-22:42:05   79.550992   79.550992
               svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
               tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 2, 2013, 1114
               tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 2, 2013, 1114
               TfFontMgr.dll   FontMgr   9.3.0.113
               TfKernel.dll   Kernel   9.3.0.113
               TFKGEOM.dll   Kernel Geom   9.3.0.113
               TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
               updaternotifications.dll   Adobe Updater Notifications Library   8.0.0.14 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   8.0.0.14
               VulcanControl.dll   Vulcan Application Control Library   5.0.0.82
               VulcanMessage5.dll   Vulcan Message Library   5.0.0.82
               WRServices.dll   WRServices Fri Mar 07 2014 15:33:10   Build 0.20204   0.20204
               wu3d.dll   U3D Writer   9.3.0.113
            Required plug-ins:
               3D Studio 15.1 (2014.1.0 x001)
               Accented Edges 15.1
               Adaptive Wide Angle 15.1
               Angled Strokes 15.1
               Average 15.1 (2014.1.0 x001)
               Bas Relief 15.1
               BMP 15.1
               Camera Raw 8.6
               Camera Raw Filter 8.6
               Chalk & Charcoal 15.1
               Charcoal 15.1
               Chrome 15.1
               Cineon 15.1 (2014.1.0 x001)
               Clouds 15.1 (2014.1.0 x001)
               Collada 15.1 (2014.1.0 x001)
               Color Halftone 15.1
               Colored Pencil 15.1
               CompuServe GIF 15.1
               Conté Crayon 15.1
               Craquelure 15.1
               Crop and Straighten Photos 15.1 (2014.1.0 x001)
               Crop and Straighten Photos Filter 15.1
               Crosshatch 15.1
               Crystallize 15.1
               Cutout 15.1
               Dark Strokes 15.1
               De-Interlace 15.1
               Dicom 15.1
               Difference Clouds 15.1 (2014.1.0 x001)
               Diffuse Glow 15.1
               Displace 15.1
               Dry Brush 15.1
               Eazel Acquire 15.1 (2014.1.0 x001)
               Embed Watermark 4.0
               Entropy 15.1 (2014.1.0 x001)
               Export Color Lookup NO VERSION
               Extrude 15.1
               FastCore Routines 15.1 (2014.1.0 x001)
               Fibers 15.1
               Film Grain 15.1
               Filter Gallery 15.1
               Flash 3D 15.1 (2014.1.0 x001)
               Fresco 15.1
               Glass 15.1
               Glowing Edges 15.1
               Google Earth 4 15.1 (2014.1.0 x001)
               Grain 15.1
               Graphic Pen 15.1
               Halftone Pattern 15.1
               HDRMergeUI 15.1
               IFF Format 15.1
               IGES 15.1 (2014.1.0 x001)
               Ink Outlines 15.1
               JPEG 2000 15.1
               Kurtosis 15.1 (2014.1.0 x001)
               Lens Blur 15.1
               Lens Correction 15.1
               Lens Flare 15.1
               Liquify 15.1
               Matlab Operation 15.1 (2014.1.0 x001)
               Maximum 15.1 (2014.1.0 x001)
               Mean 15.1 (2014.1.0 x001)
               Measurement Core 15.1 (2014.1.0 x001)
               Median 15.1 (2014.1.0 x001)
               Mezzotint 15.1
               Minimum 15.1 (2014.1.0 x001)
               MMXCore Routines 15.1 (2014.1.0 x001)
               Mosaic Tiles 15.1
               Multiprocessor Support 15.1 (2014.1.0 x001)
               Neon Glow 15.1
               Note Paper 15.1
               NTSC Colors 15.1 (2014.1.0 x001)
               Ocean Ripple 15.1
               OpenEXR 15.1
               Paint Daubs 15.1
               Palette Knife 15.1
               Patchwork 15.1
               Paths to Illustrator 15.1
               PCX 15.1 (2014.1.0 x001)
               Photocopy 15.1
               Photoshop 3D Engine 15.1 (2014.1.0 x001)
               Photoshop Touch 14.0
               Picture Package Filter 15.1 (2014.1.0 x001)
               Pinch 15.1
               Pixar 15.1 (2014.1.0 x001)
               Plaster 15.1
               Plastic Wrap 15.1
               PLY 15.1 (2014.1.0 x001)
               PNG 15.1
               Pointillize 15.1
               Polar Coordinates 15.1
               Portable Bit Map 15.1 (2014.1.0 x001)
               Poster Edges 15.1
               Radial Blur 15.1
               Radiance 15.1 (2014.1.0 x001)
               Range 15.1 (2014.1.0 x001)
               Read Watermark 4.0
               Render Color Lookup Grid NO VERSION
               Reticulation 15.1
               Ripple 15.1
               Rough Pastels 15.1
               Save for Web 15.1
               ScriptingSupport 15.1
               Shake Reduction 15.1
               Shear 15.1
               Skewness 15.1 (2014.1.0 x001)
               Smart Blur 15.1
               Smudge Stick 15.1
               Solarize 15.1 (2014.1.0 x001)
               Spatter 15.1
               Spherize 15.1
               Sponge 15.1
               Sprayed Strokes 15.1
               Stained Glass 15.1
               Stamp 15.1
               Standard Deviation 15.1 (2014.1.0 x001)
               STL 15.1 (2014.1.0 x001)
               Sumi-e 15.1
               Summation 15.1 (2014.1.0 x001)
               Targa 15.1
               Texturizer 15.1
               Tiles 15.1
               Torn Edges 15.1
               Twirl 15.1
               U3D 15.1 (2014.1.0 x001)
               Underpainting 15.1
               Vanishing Point 15.1
               Variance 15.1 (2014.1.0 x001)
               Virtual Reality Modeling Language | VRML 15.1 (2014.1.0 x001)
               Water Paper 15.1
               Watercolor 15.1
               Wave 15.1
               Wavefront|OBJ 15.1 (2014.1.0 x001)
               WIA Support 15.1 (2014.1.0 x001)
               Wind 15.1
               Wireless Bitmap 15.1 (2014.1.0 x001)
               ZigZag 15.1
            Optional and third party plug-ins:
               CUR (Windows Cursor) NO VERSION
               GREYCstoration NO VERSION
               ICO (Windows Icon) NO VERSION
               Reduce Noise 7.0.0.0
               ScriptListener 13.0
               StarFilter Pro 3 3.0.5.1
               SuperPNG 2.0
            Plug-ins that failed to load: NONE
            Flash:
               Adobe Kuler
            Installed TWAIN devices: NONE
