3 Replies Latest reply: Aug 11, 2014 9:00 AM by SBA Dev RSS
    ColdFusion 11 Application Server 3284 | ColdFusion 11 Application Server cannot be found...
    SBA Dev Community Member
      Trying to roll this server into production but keep having errors popup on Event Viewer:
      After dealing with the issue of not being able to restart the CF service and applying the hf1100-3776060.jar hotfix - I continue to receive the following error
      The description for Event ID 3 from source ColdFusion 11 Application Server cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
      If the event originated on another computer, the display information had to be saved with the event.
      The following information was included with the event:
      3284
      the message resource is present but the message is not found in the string/message table
      Any help will be greatly appreciated!
      Thank you!
