1 Reply Latest reply on Aug 7, 2014 9:24 AM by A.T. Romano
    Picture in Picture not exporting? (semi emergency)
      So I am making a video for work that involves using PIP. It looks perfect in the .prel, but when I export it to any form, the PIP disappears.
      I have made sure that the eye is open and I copied the exact things the tutorials did.
      I am using Adobe Premiere Elements 12.
        • 1. Re: Picture in Picture not exporting? (semi emergency)
          A.T. Romano Level 7
          For now I am assuming that your Premiere Elements 12 is on Windows 7, 8, or 8.1 64 bit.
          What specific PiP effect did you use....was it from fxEffects/Presets and one of the 25% or 40% ones or did you create the picture in picture effect by scaling down an image over the background below it?
          I suspect that you have a project mismatch of settings somewhere along the line, so prepare yourself for the following questions.besides the details of how you created the PiP effect.
          1. What are the properties of your source media - brand/model/settings for camera that recorded the files
          Video Compress
          Audio Compress
          Frame Size
          Frame Rate
          Interlaced or Progressive
          File Extension
          Pixel Aspect Ratio
          2. When you played back the Timeline content in the Edit area monitor, did the monitor space have any black borders?
          3. What are the details of your export...
          Publish+Share/what/what and what preset? Did you use the defaults for the preset selected or did you customize the preset
          under the Advanced Button/Video Tab of that preset?
          Let us start here, and then we can decided what next based on your details.
