3 Replies Latest reply: Aug 7, 2014 1:47 PM by revilo RSS
    Animation export problem
    revilo Community Member
      I am using CS5 to make a simple animation to use in gif form. When I play it in CS5 it looks fine , when I open the Save for Web and Devices menu and play it there it looks ok , but when I use the Preview button in that menu it goes wrong , the images all pile up and the final image shows all the previous images. This is how it looks in the gif that I save from that menu too. Is there an obvious reason for this?
        • 1. Re: Animation export problem
          Nancy O. CommunityMVP
          Sounds like the bleed through is due to image transparency.  Try saving your GIF without transparency and then preview in browsers.
          Nancy O.
          • 2. Re: Animation export problem
            Hi and thanks for the speedy reply . I actually want a transparent gif at
            the end , sorry , should have mentioned that. I can draw a series of
            transparent layers and that works ok , the problem comes when I import a
            gif or movie drawn using Pencil . It may be connected with the way it
            creates both Frames and Layers in the Layers palette , I'm not sure. As I
            say , it looks fine playing it in CS5 , and one time I managed to correct
            it but have no idea how I did it , and have not been able to repeat that.
            • 3. Re: Animation export problem
              Problem solved , there were both layers and frames in the layers palette , same number of each when I loaded a gif from another source , or due to my following some option I thought I should do , like Flatten Frames into Layers. When I deleted all the Layers in the Layer Palette and just left the Frames there , it works fine. I think there are other problems with importing gifs from other apps though , , maybe I'd be better off just working from scratch in Photoshop.
              Thanks to Nancy O for responding
