25 Replies Latest reply on Aug 22, 2014 4:03 AM by [Jongware]
    Finding and replacing Paragraph Style of last line in a bulletted list?
    nikicreates
      I'm wondering if there's a way (or a script out there) to automate finding the last item of a bulletted list and apply a paragraph style? I'm dealing with multiple, hundred-page documents with tons of bulletted lists, and currently I'm applying a paragraph style to each of these in order to increase the space below the list and the top of the next paragraph.
      Suggestions?
        • 1. Re: Finding and replacing Paragraph Style of last line in a bulletted list?
          Kai Rübsamen Level 4
          It’s not clear to me, if the bullets are formatted at this time or how you indentify them.
          But try the following:
          app.findGrepPreferences = app.changeGrepPreferences = null;
          app.findGrepPreferences.properties = { bulletsAndNumberingListType: ListType.BULLET_LIST };
          var allFounds = app.findGrep();
          for ( var i = 0; i < allFounds.length; i++ ) {
              var curFound = allFounds[i];
              var allParas = curFound.paragraphs;
              var nParas = allParas.length;
              allParas[nParas-1].appliedParagraphStyle = "bulletLast";
          –Kai
          • 2. Re: Finding and replacing Paragraph Style of last line in a bulletted list?
            nikicreates Level 1
            YES! Kai you are awesome, this is perfect and will save so many hours!!
            Thank you!!!!
            • 3. Re: Finding and replacing Paragraph Style of last line in a bulletted list?
              Obi-wan Kenobi Level 5
              Hi Kai,
              I do it with a little grep search.
              • 4. Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                Hi Obi-wan, your way with grep ist clever. I did it in the past in a similiar way. The benefit of the script is, that it could also style the other parts of the bulleted list (all bullets, only the first bullet, the first and last bullet) or could be part of a larger script, that do some other styling or clean up.
                –Kai
                • 5. Re: Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                  To show also a screen: If the body style has no space after, there are sometimes 3 styles for the list needed.
                  var bulletStyle = "allBullets",
                      bulletFirst = "firstBullet",
                      lastBullet = "lastBullet";
                          // whole list
                          allParas.everyItem().appliedParagraphStyle = "allBullets";
                          // first bullet
                          allParas[0].appliedParagraphStyle = "firstBullet";
                          // last bullet
                          allParas[allParas.length-1].appliedParagraphStyle = "bulletLast";
                  • 6. Re: Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                    Hi Kai,
                    This last [JS] is perfect and more interesting (does what your first script does!)  [works fine with ID CC 2014]. I really like it and I put it in my ID scripts panel.
                    Many thanks.
                    A little error on line 17, fixed:
                    allParas[allParas.length-1].appliedParagraphStyle = "lastBullet";
                    A good idea to add: an UI that allows the user to choose the three para styles to be treated.
                    • 7. Re: Re: Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                      Ah, this writing for the styles was not intended, since I saved the names already in the variables at the beginning of the script.
                      Limitation: This will not work with paragraph styles in groups at the moment and: What if there is no list instead there are typed bullets followed by a tab. So a little GREP-search could be included. Your idea with the UI sounds interesting. Since I have no idea how to do this and since I never built a UI before, this could be my little first one ;-) In the meantime the corrected version.
                          firstBulletStyle = "firstBullet",
                          lastBulletStyle = "lastBullet";
                              // whole list
                              allParas.everyItem().appliedParagraphStyle = bulletStyle;
                              // first bullet
                              allParas[0].appliedParagraphStyle = firstBulletStyle;
                              // last bullet
                              allParas[allParas.length-1].appliedParagraphStyle = lastBulletStyle;
                      • 8. Re: Re: Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                        Hi Obi-wan,
                        here it is, with some lines more ;-) Try also the editField: E.g. if you have no list already, you could search for '•\t' or '-\x20{2}' or '-\s+'. Notice, that this will also remove those characters too.
                        And: If you start the script a second time, your first choice will be overwritten. The script should also work with paragraph styles in groups.
                        // ApplyStylesToBulletedLists.jsx
                        // Kai Rübsamen, www.ruebiarts.de
                        // DESCRIPTION: Search for bullets and apply styles
                        if ( app.scriptPreferences.version >= 6 ) {
                          app.doScript( main, ScriptLanguage.JAVASCRIPT , [], UndoModes.ENTIRE_SCRIPT, "Search and style bulleted lists" );
                        else {
                          main();
                        function main() {
                        // make certain that user interaction (display of dialogs, etc.) is turned on
                        app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
                        if ( app.documents.length == 0 ) {
                          alert ( "Open a document!" );
                          exit();
                        var curDoc = app.activeDocument;
                        // COLLECT ALL STYLES IN THE DOCUMENT
                        // Create a list of names and paragraph styles
                        var allParaStyleNamesList = [];
                        var allParaStylesList = [];
                        // all styles outside of groups
                        for ( var i = 0; i < curDoc.paragraphStyles.length; i++ ) {
                          var curParaStyle = curDoc.paragraphStyles[i];
                          allParaStyleNamesList.push( curParaStyle.name );
                          allParaStylesList.push( curParaStyle );
                        // all styles inside of groups
                        for ( var i = 0; i < curDoc.paragraphStyleGroups.length; i++ ) {
                          var curStyleGroup = curDoc.paragraphStyleGroups[i];
                          for ( var j = 0; j < curStyleGroup.paragraphStyles.length; j++ ) {
                            allParaStyleNamesList.push( curStyleGroup.paragraphStyles[j].name + "  ( " + curStyleGroup.name + " )" );
                            allParaStylesList.push( curStyleGroup.paragraphStyles[j] );
                        // the slice() method returns a copy of the array into a new array object
                        var displayNames = allParaStyleNamesList.slice(2);
                        // insert a new element at the beginning
                        displayNames.unshift( "Choose a style" );
                        // CREATE THE DIALOG
                        var dlg = app.dialogs.add({ name: "Style bulleted list" }); // the dialog container
                        var min_width_left = 110;
                        var min_width_right = 230;
                        with ( dlg.dialogColumns.add() ) { // at least one column
                          with ( dialogRows.add() ) { // row
                            staticTexts.add({ staticLabel: "Required:" });
                          with ( borderPanels.add() ) { // border
                            with (dialogColumns.add()) { // column
                                staticTexts.add({ staticLabel: "Main bullet style:" , minWidth: min_width_left });
                                var mainStyle = dropdowns.add({ stringList: displayNames, selectedIndex: 0 , minWidth: min_width_right });
                              }  // end dialogRows
                            } // end dialogCols
                          } // end borderPanels
                            staticTexts.add({ staticLabel: "Optional:" });
                                staticTexts.add({ staticLabel: "First bullet style:" , minWidth: min_width_left });
                                var firstStyle = dropdowns.add({ stringList: displayNames, selectedIndex: 0 , minWidth: min_width_right });
                                staticTexts.add({ staticLabel: "Last bullet style:" , minWidth: min_width_left });
                                var lastStyle = dropdowns.add({ stringList: displayNames, selectedIndex: 0 , minWidth: min_width_right });
                              } // end dialogRows
                            } // end dialogCols
                            staticTexts.add({ staticLabel: "I have no list so far and want to remove some garbage too!" });
                            with ( dialogColumns.add() ) { // column
                              with (dialogRows.add() ) { // row
                                staticTexts.add({ staticLabel: "Search for:", minWidth: min_width_left });
                                var text_edit_box = textEditboxes.add({ minWidth: min_width_right });
                              } // end dialogRows
                            } // end dialogCols
                        } // end dialogCols
                        //  show the dialog and save users choice
                        if( dlg.show() ){
                          var mainParaIndex = mainStyle.selectedIndex;
                          var firstParaIndex = firstStyle.selectedIndex;
                          var lastParaIndex = lastStyle.selectedIndex;
                          var dlgStr = text_edit_box.editContents;
                          dlg.destroy();
                        else {
                          dlg.destroy();
                          exit();
                        // test the choice for the main style
                        if ( mainParaIndex != 0 ) {
                          var mainBulletStyle = allParaStylesList[mainParaIndex+1];
                        else {
                          alert ( "Choose at least the main style for all bullets!" );
                          exit();
                        // SEARCH AND STYLE THE BULLETS
                        if ( dlgStr != "" ) {
                          app.findGrepPreferences.findWhat = dlgStr + "(.)";
                          app.changeGrepPreferences.changeTo = "$1";
                          app.changeGrepPreferences.properties = { bulletsAndNumberingListType: ListType.BULLET_LIST };
                          app.changeGrep();
                          allParas.everyItem().appliedParagraphStyle = mainBulletStyle; // whole list
                          if ( firstParaIndex != 0 ) {
                            allParas[0].appliedParagraphStyle = allParaStylesList[firstParaIndex+1]; // first bullet
                          if ( lastParaIndex != 0 ) {
                            allParas[allParas.length-1].appliedParagraphStyle = allParaStylesList[lastParaIndex+1]; // last bullet
                        } // end main
                        • 9. Re: Re: Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                          Hi Kai,
                          I'll test it with pleasure. I'll let you know. Thanks!
                          • 10. Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                            Hi Kai,
                            Doing this with paras styles without auto-numbering could be a fine way!
                            • 11. Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                              I have no idea what that means? Everything is o.k.? Everything is o.k., but in the case of … ? It would be additional nice … ?
                              • 12. Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                                Kai,
                                What I mean is that the script is too limited.
                                The idea would be to treat any group of paragraphs predefined by "Style 0" style as follows: Style 1 for the first para, Style 2 for the following paras, Style 3 for the last para.
                                In my sample, the script does not work and stop on the code line 142.
                                • 13. Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                                  Sorry to hear, that you got an error. I have no problems here. If you provide a sample-doc I will try to fix this.
                                  The original intention of the script was not to find paragraphs with predefined styles and that’s also not, was the actual script does!
                                  The script will search either for bulleted lists or for normal paragraphs that look like bulleted lists. In the last case, you must insert some grep code. Since we tested it here with two guys, I would think, it does what it should do.
                                  • 14. Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                                    Kai,
                                    Don't be sorry! The script works very fine in the way you've written it.
                                    It doesn't work in another case where I find interesting to make it work. That's what I show in my sample:
                                    I have a group of paras styled with "Style 0" and I want to apply: Style 1 to the first para, Style 2 to the following and Style 3 to the last.
                                    Here, I don't use (auto-numbering or manual) bullets.
                                    So, I think "bullets" should not be an essential criterion for research.
                                    For me, the good way is:
                                    Search a paras group (in sequence) with the same style (no manual bullet used but possibly auto-numbering)
                                    or
                                    Search a paras group (in sequence) with the same manual bullet
                                    or
                                    Search a paras group (in sequence) with the same style and the same manual bullet.
                                    • 15. Re: Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                                      My problem is, that I don’t know at the moment how single paragraphs with manual bullets can be treated at one list. This is easier, if there is already a list. You can check this, if you search for style 0 (all paragraphs are highlighted) or if you search with e.g. '•\t.+\r' (only one paragraph is highlighted).
                                      edit: Ah, maybe '(•\t.+\r)+' this will work ;-)
                                      In the meantime. Something like that for your first need?
                                      // Enter your style names
                                      var paraStyle_0 = "style 0",
                                          paraStyle_1 = "style 1",
                                          paraStyle_2 = "style 2";
                                          paraStyle_3 = "style 3";
                                      app.findGrepPreferences.properties = { appliedParagraphStyle: paraStyle_0 };
                                              // whole list
                                              allParas.everyItem().appliedParagraphStyle = paraStyle_2;
                                              // first bullet
                                              allParas[0].appliedParagraphStyle = paraStyle_1;
                                              // last bullet
                                              allParas[allParas.length-1].appliedParagraphStyle = paraStyle_3;
                                      • 16. Re: Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                                        Kai,
                                        I've tested it. Cool!
                                        If you include the UI and the Grep research, your script will be PERFECT !!
                                        • 17. Re: Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                                          What could be a reason fo this one? "Search a paras group (in sequence) with the same style and the same manual bullet."
                                          I would say, the script should cover 3 topics:
                                          1. Search a paras group (in sequence) with the same style (no manual bullet used but possibly auto-numbering)
                                          2. Search a paras group (in sequence) with the same manual bullet
                                          3. Search a paras group (in sequence) that has already a local real bulleted list applied
                                          I will try to figure that out, but give me some time
                                          • 18. Re: Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                                            What I mean by:
                                            When we import a Word file, we can have several paras groups with the same bullet BUT, in the ID Layout, we can choose to use several different "Style 0" [Style 0a, Style 0b …] to format these paras, like in this sample:
                                            Before script:
                                            After script:
                                            A good idea to be included too:
                                            You search a para style "Style 0" with manual bullet and you apply the 3 para styles deleting the manual bullet replacing it by a object placed in a library. As:
                                            In fact, when I imagine a script, I try to include in it things I can do with it. That always makes it more complex, but as I have ideas, I'm not satisfied!
                                            That said, nothing forces you to continue! I have other extensions in mind such as nesting multiple levels of styles!
                                            • 19. Re: Re: Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                                              I am not interested to script elements from a library at the moment, but I’m interested in playing with dialogs. Here is the next and maybe last version:
                                              // ApplyStylesToLists.jsx
                                              // Vers. 1.1
                                              // DESCRIPTION: Search for lists and apply styles
                                                app.doScript( main, ScriptLanguage.JAVASCRIPT , [], UndoModes.ENTIRE_SCRIPT, "Search and style lists" );
                                              else {
                                                main();
                                              function main() {
                                                exit();
                                              var displayNames = allParaStyleNamesList.slice(1);
                                              var dlg = app.dialogs.add({ name: "Style lists" }); // the dialog container
                                              var min_width_left = 140;
                                              var min_width_right = 210;
                                                  staticTexts.add({ staticLabel: "Find what:" });
                                                      staticTexts.add({ staticLabel: "Paragraph style:" , minWidth: min_width_left });
                                                      var search_style = dropdowns.add({ stringList: displayNames, selectedIndex: 0 , minWidth: min_width_right });
                                                    }  // end dialogRows
                                                      staticTexts.add( {staticLabel: "Real list:", minWidth: min_width_left} );
                                                      var cb_realList = checkboxControls.add({staticLabel: "", checkedState: false, minWidth: min_width_right});
                                                    } // end dialogRows
                                                      staticTexts.add({ staticLabel: "Manual bullets:", minWidth: min_width_left });
                                                      var text_edit_box = textEditboxes.add({ minWidth: min_width_right -120});
                                                      staticTexts.add( {staticLabel: "( E.g.: -\\s+ or •\\t )"} );
                                                    } // end dialogRows
                                                  } // end dialogCols
                                                  } // end dialogCols
                                                  staticTexts.add({ staticLabel: "Change to:" });
                                                      staticTexts.add({ staticLabel: "Main paragraph style:" , minWidth: min_width_left });
                                                      var main_style = dropdowns.add({ stringList: displayNames, selectedIndex: 0 , minWidth: min_width_right });
                                                    }  // end dialogRows
                                                      staticTexts.add({ staticLabel: "First paragraph style:" , minWidth: min_width_left });
                                                      var first_style = dropdowns.add({ stringList: displayNames, selectedIndex: 0 , minWidth: min_width_right });
                                                      staticTexts.add({ staticLabel: "Last paragraph style:" , minWidth: min_width_left });
                                                      var last_style = dropdowns.add({ stringList: displayNames, selectedIndex: 0 , minWidth: min_width_right });
                                                    } // end dialogRows
                                                      staticTexts.add( {staticLabel: "Remove bullets:", minWidth: min_width_left} );
                                                      var cb_removeBullets = checkboxControls.add({staticLabel: "", checkedState: false, minWidth: min_width_right});
                                                    } // end dialogRows
                                                  } // end dialogCols
                                              } // end dialogCols
                                              if( dlg.show() ){
                                                var searchParaIndex = search_style.selectedIndex;
                                                var mainParaIndex = main_style.selectedIndex;
                                                var firstParaIndex = first_style.selectedIndex;
                                                var lastParaIndex = last_style.selectedIndex;
                                                var cbList = cb_realList.checkedState;
                                                var cbRemove = cb_removeBullets.checkedState;
                                                dlg.destroy();
                                              else {
                                                dlg.destroy();
                                                exit();
                                              // SEARCH AND STYLE THE PARAGRAPHS
                                              // test the choice for find what
                                              if ( searchParaIndex == 0 && cbList == false && dlgStr == "" ) {
                                                alert("You must enter something!");
                                                exit();
                                              if ( searchParaIndex != 0 && cbList == false && dlgStr == "" ) { // style, no list
                                                var searchStyle = allParaStylesList[searchParaIndex];
                                                app.findGrepPreferences.properties = { appliedParagraphStyle: searchStyle };
                                              else if ( searchParaIndex != 0 && cbList == true ) { // style and list
                                                app.findGrepPreferences.properties = { appliedParagraphStyle: searchStyle, bulletsAndNumberingListType: ListType.BULLET_LIST };
                                              else if ( searchParaIndex == 0 && cbList == true && dlgStr == "" ) { // only list
                                              else if ( searchParaIndex != 0 && dlgStr != ""  && cbList == false ) { // style and grep
                                                var complGREP = "(" + dlgStr + "(.|\\n)+\\r)+";
                                                alert ( complGREP );
                                                app.findGrepPreferences.findWhat = complGREP ;
                                              else if ( dlgStr != ""  && cbList == false ) { // only grep
                                                alert ( "Notice:\r Your grep will be expanded to find the whole list\r" + complGREP );
                                              else if ( dlgStr != ""  && cbList == true ) { // warning list or grep, not both
                                                alert ( "Stop!\rYou can only search for manual bullets\rOR automatic lists, not both at the same time!" );
                                                exit();
                                              var allFounds = app.findGrep(true); // it’s important to search backwards if later manual bullets should be deleted !
                                              // test the choice for change to
                                                var mainStyle = allParaStylesList[mainParaIndex];
                                              else {
                                                alert ( "Choose at least the main style for all paragraphs!" );
                                                exit();
                                                allParas.everyItem().appliedParagraphStyle = mainStyle; // whole paragraphs
                                                  allParas[0].appliedParagraphStyle = allParaStylesList[firstParaIndex]; // first paragraph
                                                  allParas[allParas.length-1].appliedParagraphStyle = allParaStylesList[lastParaIndex]; // last paragraph
                                                if ( dlgStr != "" && cbRemove == true ) {
                                                app.findGrepPreferences.findWhat = dlgStr;
                                                curFound.changeGrep();
                                              } // end main
                                              • 20. Re: Re: Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                                                Kai,
                                                I like it! Very clever! I appreciate the "undo".
                                                Comment 1: Useful! As I insert in my own [JS], the choice on:
                                                – the entire book
                                                – all the document
                                                – selected text
                                                – the current story
                                                – until the end on the story
                                                – until the end on the document
                                                – excluding locked layers
                                                Comment 2: When we launch the script again, have the last settings definied.
                                                Comment 3: The possibility to save settings, restore those who we want to use or reset the settings by default.
                                                • 21. Re: Re: Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                                                  I thought about the scope before I posted the lines. Maybe I try it next week and put the new version on my website. If so, I will let you know.
                                                  To save or reset settings seems difficult or I have no idea how to do this.
                                                  – Kai
                                                  • 22. Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                                                    @Kai – Saving or resetting settings can be done by:
                                                    1. Write a log file and read a log file. The log file could be stored in the same folder where the script resides.
                                                    2. Use the insertLabel() method to write settings and extractLabel() method to read settings.
                                                    You have only to decide on the object you want to tag the key- and value-pairs.
                                                    2.1 App would be a candidate
                                                    2.2 Document could be a candidate (depending on the scope)
                                                    3. A combination of method 1 and method 2
                                                    3.1 Write key- and value-pairs e.g. to an added rectangle with insertLabel()
                                                    3.2 Export that rectangle as IDMS file
                                                    3.3 Import that IDMS file and read out or write out the key- and value-pairs
                                                    4. Let the script file change itself. Marc Autret once did a write up on this.
                                                    Indiscripts :: Can InDesign Script Rewrite Itself?
                                                    Uwe
                                                    • 23. Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                                                      Ouch -- Do Not Use with more than one document open! Currently, the line
                                                      searches in *all* opened documents by default ...
                                                      On the plus side: I like the dialog. I didn't test the script exhaustively (for the reason above) but it appears to work just as good under CS4.
                                                      • 24. Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                                                        Hi Guys,
                                                        thanks for your comments. So I will defenitly do something about the scope. This saving settings thing sounds to complicated for me at the moment.
                                                        I will post a new version, if I can figure out, what is the best way of offer a choice for the scope (surely another dropdown).
                                                        – Kai
                                                        P.S. This is my first script with more than 80 lines ;-)
                                                        • 25. Re: Re: Finding and replacing Paragraph Style of last line in a bulletted list?
                                                          Kai Rübsamen wrote:
                                                          .. P.S. This is my first script with more than 80 lines ;-)
                                                          Congrats on breaking a Personal Record! (My own largest script surely must be IndyFont, the demo alone is about 6,500 lines long -- I dare not speculate how much Marc added after that, with his many improvements and fully customized interface).
                                                          I think saving these settings application-wide may not be the best choice (after all, each document may have its own set of styles), but to save settings inside one document I used something like this:
                                                          if (app.activeDocument.label.match (/^JW:Cover/) == null)
                                                          return null;
                                                          lines = app.activeDocument.label.split('\n');
                                                          for (i=0; i<lines.length; i++)
                                                          if (lines[i].match(/^back=/))
                                                          back_type = lines[i].substr(lines[i].indexOf('=')+1);
                                                          .. etc. for each saved varaible
                                                          A Label may not be the best choice, some other options have been discussed as well elsewhere in this forum.
