3 Replies Latest reply on Aug 11, 2014 6:16 AM by try67
    Condition and Result not executing - enable button when a value is equal or greater
    c.l.coulter
      Hi everyone,
      I posted this in the LiveCycle Designer forum but since (I think) it is essentially a javascript question, I wanted to post it here as well - hope that is alright.
      I almost have this working but I'm missing something. I have a numeric field that contains a grand total that is fed from four other numeric fields. When the grand total is greater than or equal to 400 the Result: is to set a "submit by email" button to enabled (when the pdf first loads, I have an action that disables the "submit by email" button).
      However, when the grand total field totals 400, the submit button does not enable. But, if I put the cursor in the grand total box when it has a value of 400 and the I hit the enter key, the submit button becomes enabled! (If i ever get this working I want to visually hide this grand total box from the user).
      What "piece of the puzzle am I missing?"
      Here is the code that is generated:
      //+ GENERATED - DO NOT EDIT (ID:5C63BB92-97FF-4018-A1FE-FFB114A0814B CRC:2411975672)
      //+ Type: Action
      //+ Result2: SetEnabled("$Node2","open")
      //+ Result1: ShowDialog("information","You have met your Orientation requirements. You may now submit this form.","Congratulations!")
      //+ Node2: form1[0].SFContainerPage3[0].SigArea[0].EmailSubmitButton1[0]
      //+ Node1: form1[0].SFContainerPage3[0].TotalforValidation[0]
      //+ Condition1: NumericField("$Node1","greaterThanOrEqualTo","400")
      //+ ActionName: TotalforValidation.exit
      if (this.resolveNode("$").rawValue >= 400) {
        xfa.host.messageBox("You have met your Orientation requirements. You may now submit this form.", "Congratulations!", 3);
        oTargetField = this.resolveNode("SigArea.EmailSubmitButton1");
         oTargetField.access = "open";
      Thank you very much for your help and time.
      Best Regards,
      Chris
