1 Reply Latest reply on Aug 12, 2014 12:33 PM by bend@hydraforce.com
    Backslashes getting stripped out of my regex
    bend@hydraforce.com
      I am trying to automate some find/replace routines in dreamweaver using javascript.
      dreamweaver.setUpFindReplace({
              searchString: '<table width="\d+',
              replaceString: '<table width="100%"',
              searchWhat: "document",
              searchSource: true,
              useRegularExpressions: true
          dreamweaver.replaceAll();
      This query gets passed as: <table width="d+
      Problem: when the query string is passed to the setUpFindReplace object, the backslashes get stripped out. Backslashes are key to regular expressions. How do I get them passed from JavaScript to Dreamweaver?
      I am using CS6
      Ben
        • 1. Re: Backslashes getting stripped out of my regex
          bend@hydraforce.com Level 1
          I am still looking for a smart person to answer, but in case anyone else is having same problem I found a work-around.
          I think Java uses the backslash as an escape character and so it is not passing it to Dreamweaver. The only thing I found that works is to set a variable with the regex text, and escaping all the backslashes, then passing the variable to Dreamweaver.
          var myFind = '<table width="\\d+"'
                  searchString: myFind
                  searchSource: true,
          Note: double backslash \\d+ and single quotes ' " " ' used because query string contains double quotes.
          I tried escaping the double quotes in the search string \" but this did not work for the same reason.
          Ben (not a Java developer)
