I have a stored proc in Oracle. One of the input params is a defined type (see below). The error I get whenever I call the cfstoredproc is "expression is of wrong type ORA-06550". It's a formatted varchar, it's a table column. There's no CFPROCPARAM type that matches that.
The type is a package-defined specific format (table column): EMAIL_ADDRESSES_TABLE.USER_ID%TYPE. The table column USER_ID is: USER_ID VARCHAR2(8 BYTE). The USER_ID is a 0-padded numeric, like '00001234'
my call:
<cfstoredproc procedure="PK_EMAIL.get_emails" datasource="#MYDSN#">
<cfprocparam type="in" cfsqltype="CF_SQL_VARCHAR" variable="p_user_id" value="#formattedUserId#">
<cfprocparam type="in" cfsqltype="CF_SQL_NUMERIC" variable="p_active_only" value="1">
<cfprocresult name="spResult">
</cfstoredproc>
the stored proc function:
FUNCTION get_emails(
p_user_id IN EMAIL_ADDRESSES_TABLE.USER_ID%TYPE,
p_active_only IN SIMPLE_INTEGER
) RETURN EMAIL_ADDRESSES_TABLE;
The error I get from the system is
[Macromedia][Oracle JDBC Driver][Oracle]ORA-06550: line 1, column 18: PLS-00382: expression is of wrong type ORA-06550: line 1, column 7: PL/SQL: Statement ignored
Have something to add?
