6 Replies Latest reply on Aug 14, 2014 9:01 AM by danstein01
    Having trouble trying to control a series of elements using a for-loop
    danstein01
      I have a number of elements in my composition, which I would like to control via a for-loop. Let's say I have 5 elements, named "Element1," "Element2"..."Element5." I have created an array that stores the element names:
      elementArray = ["Element1","Element2,"Element3","Element4","Element5"]
      Now, I would like to hide all these elements using a for-loop:
      for (var i=0; i<elementArray.length; i++) {
      elementArray[i].hide();
      However, when I run this code I get an error, "Javascript error in event handler! Event Type = element"
      I'm pretty sure I'm not understanding something to do with namespace or scope here - can anyone help me with this?
        • 1. Re: Having trouble trying to control a series of elements using a for-loop
          resdesign Adobe Community Professional & MVP
          You are missing a double quote in your array and you have a code error to call the elements.
          var elementArray = ["Element1","Element2","Element3","Element4","Element5"];
          sym.$(elementArray[i]).hide();
          • 2. Re: Having trouble trying to control a series of elements using a for-loop
            danstein01 Level 1
            Thanks, redesign - but that's not the problem I'm having. What I posted was a quick, abstracted example, and I apologize for the poor typing on my part, but the issue is not in constructing the array.
            I still think that I'm not understanding something to do with scope. I will rephrase the question, with a bit more detail:
            My composition consists of a map of the United States. The user needs to be able to click on a state to select it, at which point that state becomes highlighted. I am constructing this map by using a base image which shows the entire map. Above each state, I have two elements. - First is an image of the state, but in the highlighted color - this element is named "State_on", and is initially hidden. Above "State_on," I have an identical image, NOT hidden, but with opacity set to 0 - this element serves as the button to receive the mouseclick.
            In code, I first construct an array containing the names of the highlight states . For my example, I will only use two states:
            var stArray = ["WA_on", "WY_on"];
            I then have a function which will loop through the array of state names and turn them all off:
            for (var i=0; i<stArray.length; i++)
                            var state = stArray[i];
                            sym.$(state).hide();
            If I put this piece of code into each button, it works as expected. However, I would like to consolidate things by putting this code into a function clearAll(), which I can then attach to each button as needed.
            So i have this function:
            function clearAll() {
            Then each button gets this code:
            Symbol.bindElementAction(compId, symbolName, "${_WA_off}", "click", function(sym, e) {
                 clearAll();
                 sym.$("WA_on").show();
            Once I do this, my buttons no longer work, and the console shows me the "Javascript error in event handler! Event Type = element" error.
            So it seems to me that something is wrong in the way I am scoping or addressing my elements inside the clearAll() function - as I say, if I put the code individually into each button it works, but encapsulating it into a function and then calling the function from within the button does not work.
            • 3. Re: Having trouble trying to control a series of elements using a for-loop
              joel_pau Level 5
              You must specify to Mary where you put this snippet:
              I mean: what panel?
              • 4. Re: Having trouble trying to control a series of elements using a for-loop
                danstein01 Level 1
                Hi, Joel -
                My clearAll() function is in the main code window. The entire code window (including Edge-generated comments) looks like this:
                * Adobe Edge Animate Composition Actions
                * Edit this file with caution, being careful to preserve
                * function signatures and comments starting with 'Edge' to maintain the
                * ability to interact with these actions from within Adobe Edge Animate
                (function($, Edge, compId){
                var Composition = Edge.Composition, Symbol = Edge.Symbol; // aliases for commonly used Edge classes
                var selectedState;
                         for (var i=0; i<stArray.length; i++){
                         var myState = stArray[i];
                         sym.$(myState).hide();
                   //Edge symbol: 'stage'
                   (function(symbolName) {
                      Symbol.bindElementAction(compId, symbolName, "${_WY_off}", "click", function(sym, e) {
                               clearAll();
                            // do some button stuff
                      //Edge binding end
                               clearAll();
                      //Edge binding end
                   })("stage");
                   //Edge symbol end:'stage'
                })(jQuery, AdobeEdge, "EDGE-7029468");
                I appreciate any help that anyone can provide in getting this working - thanks!
                • 5. Re: Re: Having trouble trying to control a series of elements using a for-loop
                  joel_pau Level 5
                  So, you put your code within function("stage") panel.
                  You cannot use sym (i mean script) within this panel.
                  Here is a case: How to use this panel without sym?
                  1) Within function("stage") panel, i script this code:
                     $.each(arguments,function(index,item){ item.hide(); })
                  2) Within a click event, i script this code:
                  Symbol.bindElementAction(compId, symbolName, "${_Button}", "click", function(sym, e) {
                  clearAll(sym.$("Rectangle"),sym.$("Ellipse"));
                  Therefore, i reverse your issue. Because i move sym from function("stage") to one click event.
                  Note: It will be smarter to use a class.
                  Mary will explain.
                  • 6. Re: Having trouble trying to control a series of elements using a for-loop
                    danstein01 Level 1
                    Thanks, Joel.
                    removing "sym" from the object reference in the clearAll() function helped me to solve the problem.
