The missing info is just at the end of the form, which is only 5 pages. Everything else I typed in the form is showing. What gives?
Hi;
We are working constantly to improve this service and would like to investigate this missing text. Would you be able to share the original (not filled out) PDF/form so we can investigate? Or even just that 5th page? You can email to fillandsign_support@adobe.com and include a reference to this Forum post.
Josh
Josh,
I went back to the form again, noticed the original info was not there as if it were not saved. I typed it, saw it on the screen for several hours, and then it was missing. I know I typed it in originally because when I went to retype, the auto-fill pulled up so I did not need to completely re-enter the same info again. The downloaded pdf now has the info as entered.
Sort of a weird quirk. I will email you the original form that was converted to fillable.
Thanks.
I sent the original form.
Alan [Private info removed. -Mod.]
Thanks for sending us the file, since you let us know the data was not in the form in Fill & Sign online though I don't think the file is related. We are looking into it as a high priority, thanks for reporting this issue.
Josh
