2 Replies Latest reply on Aug 11, 2014 6:12 AM by JeremyR
    populate textbox with radio box output
    JeremyR
      I have 2 sets of 5 radio boxes.
      Set 1 - CHESTQTY
      option1 - 100
      option2 - 200
      option3 - 300
      option4 - 400
      option5 - 500
      Set 2 - BACKQTY
      option1 - 1100
      option2 - 1200
      option3 - 1300
      option4 - 1400
      option5 - 1500
      Basically I'm making an order form. When a user selects any option from the CHESTQTY radio box set, I need to output a specific number to a TOTAL box. The total is always $35.00 for any option selected from CHESTQTY.
      But, they also have an option of also selecting from the BACKQTY radio box set. They are required to select at least a CHESTQTY but are not required to select a BACKQTY. But if they do select a BACKQTY also, I need to add an additional $85.00 to the previous $35.00.
      I'm kind of new to Javascript, but a total rookie when it comes to Javascripting in Acrobat. I've searched the web forever and cannot find anything like this.
      What it comes down to is this:
      CHESTQTY is required. Adds $35.00 to a text box if any of the options are selected.
      BACKQTY is optional, but if selected, also needs to add $85.00 to the previous $35.00.
      Can anyone help with this?
        • 1. Re: populate textbox with radio box output
          George_Johnson MVP & Adobe Community Professional
          If I understand what you're trying to achieve, the custom calculation script for the text field could be:
          // Custom calculation script for text field
          (function () {
              // Get the field values
              var v1 = getField("CHESTQTY").value;
              var v2 = getField("BACKQTY").value;
              // Create a variable for the sum
              var sum = 0;
              // Add 35 to the sum if any of the radio buttons is selected
              if (v1 !== "Off") sum += 35;
              // Add 85 to the sum if any of the other radio buttons is selected
              if (v2 !== "Off") sum += 85;
              // Set this field's value to the sum
              event.value = sum;
          • 2. Re: populate textbox with radio box output
            JeremyR Level 1
            Thank you!! That worked perfectly.
