1 Reply Latest reply: Aug 8, 2014 3:05 PM by Ned Murphy RSS
    Stopping reverse animation
    mentalcase129 Community Member
      I have 2 buttons.  One has a rollover event to play a movieclip and an out event to then stop the movieclip at the exact spot it was at when the mouse was moved off the button.  The button is supposed to play the same movie clip in reverse and then stop when the mouse is moved.
      I have the first button working perfectly.  The animation plays when the mouse is rolledover and the animation stops in its tracks when the mouse is rolled off.
      The second button is giving me grief though.  It took a while but I was eventually able to find some code to make the movieclip play in reverse like I wanted but the out even doesn't work.  Once the reverse animation is started it there's not stopping it until it gets to the first frame of the movieclip again.  Can anybody see from my code what needs to be done to make the reverse play stop in its tracks when the mouse moves off the button?
      Here's my code:
      gallery.stop();
      /* Mouse Over Event
      Mousing over the symbol instance executes a function in which you can add your own custom code.
      Instructions:
      1. Add your custom code on a new line after the line that says "// Start your custom code" below.
         The code will execute when the symbol instance is moused over.
      right.addEventListener(MouseEvent.MOUSE_OVER, fl_MouseOverHandler);
      function fl_MouseOverHandler(event:MouseEvent):void
          gallery.play();
      /* Mouse Out Event
      Mousing out of the symbol instance executes a function in which you can add your own custom code.
      Instructions:
         The code will execute when the symbol instance is moused out of.
      right.addEventListener(MouseEvent.MOUSE_OUT, fl_MouseOutHandler);
      function fl_MouseOutHandler(event:MouseEvent):void
          gallery.stop();
      /* Mouse Over Event
      Instructions:
      left.addEventListener(MouseEvent.MOUSE_OVER, fl_MouseOverHandler_2);
      function fl_MouseOverHandler_2(event:MouseEvent):void
      this.addEventListener(Event.ENTER_FRAME, playReverse, false, 0, true);
      function playReverse(e:Event):void {
          if (gallery.currentFrame == 1) {
              stopPlayReverse();
          } else {
              gallery.prevFrame();
      function stopPlayReverse():void {
          if (this.hasEventListener(Event.ENTER_FRAME)) {
              this.removeEventListener(Event.ENTER_FRAME, playReverse);
      /* Mouse Out Event
      Instructions:
      left.addEventListener(MouseEvent.MOUSE_OUT, fl_MouseOutHandler_3);
      function fl_MouseOutHandler_3(event:MouseEvent):void
          stop();
        • 1. Re: Stopping reverse animation
          Ned Murphy CommunityMVP
          You need to call the stopPlayReverse() function thru the MOUSE_OUT event handler.  If you rewrite that function definition line as follows it can be called directly or thru the event listener...
          left.addEventListener(MouseEvent.MOUSE_OUT, stopPlayReverse);
          function stopPlayReverse(evt:MouseEvent=null):void {
          etc...
