1 Reply Latest reply on Aug 9, 2014 2:56 AM by Peter Spier
    hiddden elements in control panel because of screen size
    Hosein
      is there a way to access all elements in control panels. for instance i can't see corner shape in control panel unless i uncheck some others in customize.???????
        • 1. Re: hiddden elements in control panel because of screen size
          Unfortunately, there is not. You get to choose which things you WANT to see, but Adobe decides which ones you will see by setting the positions and order in which they appear, and the only way you can see everything is if the panel is wide enough to hold them. If your screen is narrow, the first thing I would turn off is Quick Apply as it uses far more space in the panel than is really required.
