1 Reply Latest reply on Aug 9, 2014 7:33 PM by CtDave
    i was informed i need to purchase standard 11 or standard 12 (?) in order to make word files converted from pdf editable. how do i do this?
    mickeygs
      i was informed i need to purchase standard 11 or standard 12 from adobe in order to make files converted from pdf to word using the recently bought and installed adobe pdf exporter file. how/where do i do this?
        • 1. Re: i was informed i need to purchase standard 11 or standard 12 (?) in order to make word files converted from pdf editable. how do i do this?
          CtDave Level 6
          Currently the Acrobat version is "XI" (no "12").
          With Acrobat XI installed:
          "File - Save As Other"  --- from here you pick the supported file format for the export.
          If a PDF has content that is the output of a scanner then that output (as is the case for All scanners' output) is a picture of text and not real text.
          During an export all that can be processed is the picture. As a picture of text is not text it is understandable why Word (or other word processors) cannot edit the content.
          So, for such, prior to export run Acrobat's OCR and save.
          The export will be of the OCR content.
          Do expect to do clean of the text, spelling, punctuation, layout etc.
          This may be minor. This may be major. But, there will be some.
          Adobe as some online subscription services that can take a "proper" PDF (NOT all are eh) and export to supported file formats.
          Two are "ExportPDF" and "PDF Pack".
          Be well...
